Parts Changed, Still Showing Codes? Help!
check your wire looms for tears in the insulation. this could be causing random ground outs. i had this issue with the CKPS and Camshaft Position sensor. turned out the wires had come loose and rested against the exhaust manifold and melted a bit. fixed this and my misfire and other codes went away.
I will the PVC oil separator mod next.
Thanks!
-Burwell
I checked the wiring harness yesterday (7/31) and didn't find any tears, melted areas or bare wires. I will clean the connectors at the MAF today.
The purge valve will be in this weekend and I will get it swapped.
Does anyone have a link to a how-to or can describe how the smoke test is performed?
Yes, I can view the readings live. I will post screen shots. However, I will be ut of town until Sunday, but will post them when I return. Thanks!
Great eye there Ben. Also doesn’t show the code “state” hard fault/intermittent. But does say the ecu(motronic 5.2.1) but also shows Lr3/4
Update 8/5
Thanks Ben and Nosugar0carbs. When I go into my iLand ap on my phone, the first tile in the upper left hand corner is the Discovery | LR3 | LR4 tile - which also the only vehicle diagnosis ap I bought. Once that tile is selected, it goes into a dropdown sort of menu where one selects: Discovery, Discovery II, Lr3 or LR4. I am selecting the Discovery II option.
I think what you are seeing at the top of my screen shot is just the acknowledgement that I am in that section, but I am selecting the Discovery II.
I wasn't able to drive the 2004 Discovery 2 yesterday due to the weather, so, I couldn't get live data charts to post here yet. Also, the new purge valve is coming in today and I will get that installed.
Thanks again for all the help!
