Passenger Rad
Old Oct 1, 2007 | 09:37 PM
ajh's Avatar
ajh
Default Passenger Rad
So, the passenger heating core seems to get very hot, all the time. Is there supposed to be some kind of cut-off to cut the flow to it in hot weather? Seems to be kinda nuts to run it that hot when it isn't being used at all.
Old Oct 2, 2007 | 06:47 AM
03springer's Avatar
Default RE: Passenger Rad
I`m no expert on this but my truck would do the same thing, but on both sides. I just turn the temperature setting down to like 68 degrees on both sides and then shut it off. It helped mine.
Bob
Old Oct 2, 2007 | 07:19 AM
Ajh,
What year is your truck?
Some people by-pass the system during the summer by removing the heat hoses and joining them together.
Old Oct 2, 2007 | 10:43 AM
ajh's Avatar
ajh
It's an 03, I'm wondering if there's a solenoid in there or something that's not working right. I did finally manage to find my electrical fault yesterday and repair it. I'm not convinced it was me who introduced it either, it was a cut inside the heavy plastic covering on the passenger side in the back and fairly close to where they worked when installing the car starter. Now I just need to re-wire some of the accessories and the started but an aux fuse panel and relay go in first so I can independently fuse the various systems.
Old Oct 2, 2007 | 11:22 AM
There is no solenoid causing your problem, the blender door/motor is not work, which is common , and that is what is causing your a/c issue.
Darover
Sep 2, 2007 12:31 PM
Darover
Aug 24, 2007 11:44 AM
ajh
Jul 24, 2007 01:49 PM
Stashf
Jun 9, 2007 07:05 AM
Les
Jun 2, 2007 02:48 AM
