PB Blaster
Old Aug 14, 2007 | 10:58 AM
bgalway's Avatar
7th Gear
Default PB Blaster
After a successful O2 sensor change asisted by PB Blaster, I now have a full can lying around. Are there any other uses for this product on my Disco. Could it be used for every day "greasing" around sticky parts of my truck, such as noisy sunroof parts....
Old Aug 14, 2007 | 11:20 AM
Default RE: PB Blaster
It is not considered to be a grease but more of a penetrating oil. Trust me, hang on to it, you'll find plaenty of uses for it with time.
Old Aug 14, 2007 | 11:21 AM
S4poor's Avatar
You "can". It is a penetrating lubricant so it is used primarily for what you just used it for.
I have used it as a lubricant on many things with good results. It dissipates quicker than most lubricants though....
Save it, you'll need it again soon ;-)
Old Aug 14, 2007 | 09:15 PM
mordor110's Avatar
Yeah ditto prior replies! It's great stuff and you'll need it again. But it's not a long term lubricant as such. It's designed to get into very small gaps, hence "penetrating" I grew up (Dad)using WD40, but this is much better. Anytime you work on your exhaust system, spray this on the nuts & bolts at least an hour or so prior to trying take it apart. I've found a can of silicone spray works good on sticky winodws & sunroofs and is cleaner than most lubricants.
