periodic rattle at idle
Old Jan 28, 2008 | 09:47 AM
zerochills's Avatar
Default periodic rattle at idle
i have noticed recently that at idle after I have been driving,while the truck is either in gear or in park I can hear a periodic rattle coming from under the cab. I crawled under a was able to pin point noise from around transfer case. is there some kind of heat shield above transfer case or could the transfer case itself be making the noise? rattle lasts just a second or two and elapses for a short period before doing it again, also does not make noise consistantly?
Thanks
136000 mi.
Old Jan 28, 2008 | 09:53 AM
okdiscoguy's Avatar
Default RE: periodic rattle at idle
Not sure on a D2, but I would guess. Alsotap the cats with a rubber mallet and make sure the membrane isn't broken...
Old Jan 28, 2008 | 10:39 AM
It will be either the heat shields or a cat that is failing.
If it is a cat, you will need to find out what caused it before you replace it, or it will happen again. Have you had any check engine light issues over the last year, how about tune ups, is it current, leaking head gaskets or oil consumption??
wick_60010
Nov 22, 2017 04:25 AM
KGN96discoSE7
Sep 23, 2017 07:23 AM
94svt50
May 5, 2011 10:39 AM
westernsun
May 27, 2006 04:24 PM
n2radio
May 1, 2006 08:52 PM
