Philly Mechanic Help
Old Jan 3, 2014 | 01:22 PM
kcdiehl's Avatar
Default Philly Mechanic Help
Hey guys,
I have an engine issue, a vibration at low speeds and I've been doing all common and simple maintenence but I'm not comfortable to dive into the engine....
Does anyone know of any good indy shops around or outside of Philly? I'm in the Horsham area.....
Thanks!!!
Old Jan 3, 2014 | 01:31 PM
jeffh's Avatar
R&R Repair
301 MacDade Boulevard
Colingdale, PA 19023
484-494-9133
Frank is the owner. good guy Master Mechanic trained out of West Chester Rover.
Tell him Jeff sent you the guy with the black disco/photographer.
Used to be called Rover Repair, but LRNA has a strangle hold on anyone using the word Rover in their name. So now it is R&R Repair not sure if he has changes it online yet or not.
Old Jan 3, 2014 | 06:30 PM
kcdiehl's Avatar
Thanks Jeff. I'll call him tomorrow!!
Originally Posted by jeffh
R&R Repair
484-494-9133
Old Jan 3, 2014 | 09:41 PM
Andy2Rover's Avatar
There's another place called Skytop that's off of Delaware Ave near Sugarhouse Casino. They do great work and have fair prices.
Old Jan 3, 2014 | 10:11 PM
coors's Avatar
R&R Repair
484-494-9133
I also recommend Frank. Tell him Eric with the Black DII sent you (the one with the cracked flex plate). I'm up for inspection end of the month so, I'll be visiting him in a week or two.
Old Jan 4, 2014 | 01:43 PM
jfall's Avatar
Vibration at low speeds may be the drive shafts.
Just grease them with a grease gun.
If your check engine light is on then you can scan out the codes to at least have knowledge of what you need done.
Old Jan 5, 2014 | 09:21 AM
kcdiehl's Avatar
jfall- I thought that too but it vibrates even when started and not moving. It also will stop usually when I'm coasting too.....
Old Jan 5, 2014 | 09:32 AM
jeffh's Avatar
Do you have any codes? Check your engine and transmission mounts. also have a look at your roto flex.
Old Jan 5, 2014 | 09:47 AM
coors's Avatar
Crawl underneath and inspect your motor mounts.
At the moment, both my driver and passenger side mounts are destroyed. The engine vibrates at idle and what also happened is my catyalitic converter/y-pipe shifted causing it to rub up against the front prop shaft.
I have a thread on here with pictures. I'll try to find the link and post back.
Check you engine mounts.
Old Jan 5, 2014 | 09:49 AM
coors's Avatar
Here it is...
https://landroverforums.com/forum/sh...ad.php?t=63138
And a motor mount diy...
https://landroverforums.com/forum/sh...ad.php?t=30194
bmwrovers
28
Oct 23, 2013 01:45 PM
bmwrovers
Feb 3, 2013 08:28 PM
KingKong8247
May 15, 2011 07:46 PM
fox220
Sep 1, 2009 11:09 AM
Willy921
Jun 19, 2009 12:09 PM
