pics of the new tires on
Old 12-20-2008, 08:35 PM
discoxd's Avatar
Default pics of the new tires on
this is what it looked like when i first bought it before the lift kit and stuffName:  CIMG0885-1.jpg
and here it is as it sits now with a 2" RTE lift with OME shocks and the new(to me) BFG Mud terrains size 265/75's... i still need to trim the rear quarter panels and work out a slight rubbing issue when i turn real sharp... i think i may order up some 1" coil spacers to get a little more clearance...Name:  Image0026.jpg
Size:  78.8 KBsorry about the quality its a cell phone pic...
Old 12-20-2008, 08:49 PM
Default RE: pics of the new tires on
Man, I could never climb into in now.
Old 12-20-2008, 08:56 PM
discoxd's Avatar
my 5 foot tall 7 month pregnant g/f has a little trouble gettin in and out now....
Old 12-20-2008, 08:59 PM
I'm 5'5" and look pregnant.
Old 12-20-2008, 09:24 PM
AK Rover's Avatar
I like the looks of it. Can't wait until mine has a similar stance. I've already decided on 235/85's after I put the lift on.
I would put money that your rubbing is the tire rubbing on the trailing arm (or whatever Rover calls it). I had the same problem with my 2001 Dodge when I put 305/70R16's under the stock suspension on stock wheels. I just resigned myself to the fact an extended cab, long box truck wasn't going to turn sharp anyway and left it alone. A wheel with less backspacing or a smaller wheels spacer should push the tires out far enough to eliminate your rubbing problem.
Old 12-20-2008, 09:39 PM
discoxd's Avatar
i just dont turn super sharp anymore... problem solved...
Old 12-20-2008, 10:44 PM
sloppyjoe's Avatar
kick ***
Old 12-20-2008, 10:50 PM
discoxd's Avatar
i think i may order the RTE 2" spacers... but i know if i go up that much more i am gonna run into pinion angle issues or driveshaft problems and i will need to extend my brake lines and a few other things... maybe next year when i get back from this two month job i have to do out of town...
Old 12-20-2008, 10:58 PM
sloppyjoe's Avatar
ORIGINAL: discoxd
i think the height is good as is,,,
Old 12-20-2008, 11:06 PM
discoxd's Avatar
i wheel with guys who drive things like thisName:  downsized_1010081349a.jpg
Size:  56.9 KB i could always use a little more ground clearance...
Quick Reply: pics of the new tires on
