A- Pillar
Old Feb 6, 2012 | 02:50 PM
Zonk872's Avatar
Default A- Pillar
How hard is it to replace an A-Pillar (exterior)? I see the cheapest one on British Parts of Utah site for $99.00. Will I need anything extra in terms of clips? I assume that the three on the backside come with it but not sure of the black clips on the door well side... look like post pins.
Thanks-
Old Feb 6, 2012 | 03:07 PM
jafir's Avatar
Old Feb 6, 2012 | 04:00 PM
Zonk872's Avatar
Thanks!
Old Feb 6, 2012 | 05:56 PM
buick215's Avatar
I have never replaced one but I have read on this forum that it is a pain to do.
Old Feb 6, 2012 | 07:59 PM
bosshogt's Avatar
I pulled mine off when I was fixing a leak. There are 3 steel spring clips that hold it on in beside your windshield. The trick is to line it up where you want it to be, before you tap it down with a rubber mallet. Then you have to pull it around the pillar and insert the fasteners from the back. Try and test fit it a few times. A Nylon or plastic prybar is great to have, as it can help you pry it up from the windshield, without putting metal on your windshield.
Twins Disco
Dec 16, 2013 01:50 PM
ralphobell
Apr 1, 2013 11:09 AM
rmally
Apr 6, 2008 10:22 PM
Hare
Mar 25, 2008 01:16 PM
qslide99
May 2, 2007 02:08 PM
