Planning Valve Cover Gasket Replacement
I have a slight leak at the back of the passenger side valve cover. Was considering nipping the bolts, and as you say yours were loose......
It's that funny looking star bolt as I recall. Is it anything special or just a reverse torx? Anyone know the size, off hand?
Yea I had a noticable buildup of oil leaking down from the around the gaskets. I did try to tighten it, during which I accidentally snapped 2 of the bolt heads off which forced my hand to replace the gaskets. Mine were pretty loose, even the inside ones which you can't get to without removing the intake manifold.
It's an 8mm 12 point head. You'll need a small socket though to fit in that groove.
The one I used looked like this:
cappedup (04-08-2015)
It took ME about 7 hours. I started after work and finished at about 1am. Now I also wasted a lot of time with a rounded bolt head on the intake manifold (I cracked three 10mm sockets!). Also about an hour of that was cleaning the valve covers once I got them off. This was also my first project beyond changing the oil. So it's doable, nothing too difficult, and depending on your comfort level you could do it faster.
