Please help identify the part leaking
Old Nov 27, 2022 | 11:10 AM
Massrover's Avatar
Default Please help identify the part leaking
2003 Land Rover discovery 2 v8. Oil spot under front driver side. See pictures. Please help me identify what may be leaking. It’s seems to be part of the steering system? I’m a noob sorry. Any help would be great. Thanks
Old Nov 27, 2022 | 12:30 PM
frostythor's Avatar
No some times it hard to find the leak, I was chasing a leak lept wiping off the oil, finaly found it iwas coming out of my battery box?????, turn out it was oil from my hydrualic jack, so I refiled it and put id bacl rubber gromit side up no more leak
Old Nov 27, 2022 | 01:05 PM
Massrover's Avatar
Default Gear box
It appears to be leaking from the gear box. I know my pictures aren’t great but does that sound about right. It’s dry above the oily area and the gear box has the hydraulic power steering fluid in it… can I connect the dots here?
Old Nov 28, 2022 | 10:21 AM
zski128's Avatar
A leaking steering box is pretty common. If you are sure it’s dry above and around the power steering pump you are probably correct.
Old Nov 28, 2022 | 12:04 PM
Discorama's Avatar
By any coincidence, did you turn the steering wheel with engine off? I get the same leak when I do that. Otherwise the area is just wet, loss is negligible (takes years to go from max to min mark).
Old Nov 29, 2022 | 08:49 AM
Massrover's Avatar
I don’t think I did that since it’s not easy to do. The PS reservoir was at min level. And I refilled with what I had on the shelf. I’ll keep watching it to see but there’s a brown splatter stain under that spot.
Old Dec 1, 2022 | 02:39 AM
The Deputy's Avatar
Take a look from above, where the lines connect, very common for lines to rust out in this area.
Old Dec 3, 2022 | 10:48 AM
redrover75's Avatar
I have pretty serious power steering leak, I have tried the cleaning and watching method, could not really discren the leak this way. Would the flourescent leak detection kit work in power steering fluid?
I am hoping it is only the high pressure hose, replaced the pump not too long ago, and not the rack. Which would be a much bigger PITA.
Old Dec 4, 2022 | 11:31 AM
JohnZo's Avatar
I have seen seal kits available for the top and steering input shaft. Seems like a simple task, but it's still on my to-do list.
Brigh04disco2
Aug 21, 2022 05:07 AM
Ahmed Salad
Aug 15, 2018 03:10 PM
Spike555
May 24, 2009 03:45 PM
