PLEASE HELP, NO POWER
Old May 15, 2006 | 08:49 AM
cassie11's Avatar
Default PLEASE HELP, NO POWER
My 1997 land rover needed a new starter, so we tried to change it. we werent able to due to a bolt that wouldnt move. After putting it all together, we found that the truck had no power. no lights, no nothing. it was like the battery was disconnected, the battery has a full charge. is there a reset button, is it something else? please help. cassie
Old May 15, 2006 | 01:11 PM
Default RE: PLEASE HELP, NO POWER
Have you checked to see if the factory alarm is working, do you have an aftermarket alarm? If so have you gone thru resetting either of them. I am assuming you have inspected all grounds and that you did put all the wires back in the right location on the starter? Have you tried locking and unlocking your doors 3 time slowly, this will reset some things on the factory alarm?
Other then that I don't have a clue.
Mike
Old May 15, 2006 | 01:28 PM
cassie11's Avatar
We did check the grounds, everything was returned to its original spot wire wise, no reset of the alarm, how is that done? I don't think I can do the lock thing, I have no power at all. I can do the drivers side door, but it lock and unlock all of them....?
Old May 28, 2006 | 02:34 PM
duboff's Avatar
just a thought. try disconnecting the battery for one hour and then check it again. Do you have dash lights, interior lights. recheck battery connections, charge levels.. check the owners manual for a fuse or relay that is in the starting system. If you or someone you know has one plug in a obdII as see if anything comes up as a fault. Hope it helps. gotta love a rover. duboff
bflener
Oct 9, 2010 05:10 PM
chriswatkins79
Apr 5, 2010 06:40 AM
thehosst
Jun 5, 2008 08:44 PM
DISCOBOY2000
May 19, 2007 04:41 AM
