Plug & Play trailer wiring harness, now tail lights don't work
Old Aug 31, 2012 | 03:12 PM
04duxlr's Avatar
It looks like the only place the two brake light wires for the LH and RH side are at the same connector is at CO295, which is at the LH B post.
Old Aug 31, 2012 | 04:17 PM
hankeester's Avatar
Taking it to Paul Schram tonight. Need brake lights working.
Old Aug 31, 2012 | 07:20 PM
jfall's Avatar
The brake light switch is a compound switch, if I remember.
Consisting of two switches.
One part for the ABS.
One part for the actual brake lights.
And, on a D1 there is a mechanical vacuum switch for the cruise.
Not sure if the vacuum switch exists on the D2.
When the truck is off, you may want to pull out a brake lamp and try to put an ohm meter across the middle power pin and the socket ground on X10 scale to see if there is a dead short or not.
You may want to get the ohm meter on X10 and put it against the socket ground where the socket of the bulb grounds and then against a good metal fitting or scrape a small bit off the trailer hitch receiver for a ground point. That should be a dead short.
Could you have fried your brake switch - YES.
If someone put an over amp fuse in for the brake lights - that may have not blown the fuse but blown the weakest link - maybe your brake switch.
Check that the fuse for the brake lights is the proper amp rating.
If you fried the brake lights after connecting to the trailer, then I would advocate the connections to the trailer may be suspect.
I would take it all back apart.
Then use a battery to check that the wires you connect to on the trailer actually do what you think they do.
Going just by colors - is not so smart.
Make sure brake lights light up just brakes and all that.
On am american trailer the brakes and turn signals are the brake light.
On the rover --
Brake light is a distinct bulb.
The turn is a distinct bulb.
Atlantic British may have sold you a gizmo that uses diodes to
conduct the current to the same bulb..
Brake bulb-------|<----- turn signal
+------|<------brake lamp
This would be a suitable circuit with two diodes.
Old Aug 31, 2012 | 09:10 PM
lr2001silver's Avatar
Banned
So what the hell happened with your truck?
Old Sep 1, 2012 | 09:19 AM
hankeester's Avatar
Don't know. It's at Paul Schrams place getting taken care of..
Old Sep 1, 2012 | 10:31 AM
Banned
Cool if anyone can figure it out he will for sure.
Old Sep 1, 2012 | 12:12 PM
mwindth's Avatar
Originally Posted by Big Jim Swade
I installed the same one from AB back in January and installation was a snap and everything works fine.
Ditto, except I installed mine in 2009...check fuse, voltage and then each bulb.
Old Sep 3, 2012 | 10:41 AM
hankeester's Avatar
Coincidentally, all three bulbs were burnt out. I didn't bother checking them because I didn't think all would burn out at the same time. It cost me $140 to replace 3 bulbs. Solid!
Old Sep 3, 2012 | 11:26 AM
Banned
Thank the man for his time.
Old Sep 4, 2012 | 08:16 AM
04duxlr's Avatar
Holy crap - I was right! I wonder how long they were out. Be glad you didn't get rear-ended!
