plug/wire/gasket package?
Old Sep 3, 2008 | 03:23 PM
miahman98's Avatar
Default plug/wire/gasket package?
Does anyone sell a plug/wire/gasket package? I would like to get the Magnacore wires if its possible. And what should I be expecting to pay for everything?
I have a 02 discovery II se.
Thanks.
Old Sep 3, 2008 | 03:34 PM
Disco2Guy's Avatar
Default RE: plug/wire/gasket package?
http://www.lrrforums.com/store/index...ategory_id=225
Old Sep 3, 2008 | 03:46 PM
Jupiter Rover's Avatar
I bought my wires from http://roverconnection.com Rover connection also sells the gaskets.
This place also sells the wires http://www.apexperformance.net/
You can just get the plugs at nearly any auto parts store.
Old Sep 3, 2008 | 04:03 PM
If you buy everything from one place yoiu will save money on shipping. You may pay more for the plug wires for example, but combining shipping is a sure fire way to save $.
www.atlanticbritish.com has everything you need.
So does www.roverconnection.com
Load up your shopping cart and compare shipping costs.
If they will not give you a exact cost on shipping then I wouldnt buy from them, but thats just me.
Old Sep 4, 2008 | 01:39 AM
miahman98's Avatar
Thanks guys...
Old Sep 5, 2008 | 02:01 PM
Willie 00D2's Avatar
Theres is a coolant hose that runs under the intake manifold you might want to replace if your going to take the intake off. I just changed all of my hoses and thermostat. They get spongy after awhile.
Willie
Old Sep 5, 2008 | 02:10 PM
ORIGINAL: miahman98
Thanks guys...
To get the best stuff, buy only Rover gasket sets and head bolts, either Rover Connection or Atlantic British are the best for that.
The Magnacors should not be bought from Atlantic British because they only sell the 7mm wires and you want the 8mm.
If you want, cal Tony, eh will give you a fair price on the wires, which he stocks. 650-365-4145.
Old Sep 22, 2008 | 01:06 PM
miahman98's Avatar
When it comes to the gasket does it matter if the disco has secondary air.
Old Sep 22, 2008 | 01:24 PM
ek5usmc's Avatar
As for this manifold gasket, I'm putting magnacor wires on also, at what point do you want to change the gasket? 04 Disco 2 with 76k.
Old Sep 22, 2008 | 01:30 PM
8 mm wires, right??
You can replace the wires, even with secondary air, without removing the manifold.
