Plugging the SAI head holes?
Old 11-11-2014 | 12:03 PM
knightmetro's Avatar
I seem to be having an issue finding one online anyway.
No luck so far. Today I'll be hitting up some local stores to see what I can find.
Old 11-11-2014 | 01:39 PM
RicketyTick's Avatar
Good luck!
I know M16 x 1.50 is common but is 18tpi.
M16 x 1.25 is not so common I think but, hopefully you'll be able to find something.
Carry one of the fittings with you so if you can't find a plug you may get lucky and find a cap to fit the big end. I'm thinking a cap may be easier to find.
Anyway, just trying to help. Let us know what you come up with.
Old 11-11-2014 | 01:52 PM
Looks like we are just going to see if we can weld the fitting shut and bolt them back in. Should cost a cheeseburger and fries. We are just finding nothing local. Even Fastenal can't special order that size.
Plus if I have to put the SAI back in, i'll just drill them back out.
Old 11-11-2014 | 02:36 PM
Yeah weld it up. They're stainless I think.
Round here they want $50 just to switch the welder on. I do most of my welding myself but I did have to get a 6" to 8" crack in an inch thick cast iron wood heater welded up with nickel rod and they hit me up for bout $150 and that was with me taking the heater apart myself and just carrying the part that needed welding.
oh well....lots of overhead in a shop like that and I can't complain, they did a much better job than I could have done. plus I wanted it welded on both sides and was kind of particular about how I wanted it done which probably cost me extra.
Old 11-11-2014 | 03:46 PM
dusty1's Avatar
I was thinking something like this and a common 1/8 plug
Auto Meter
Old 11-11-2014 | 05:35 PM
That's what i was thinking dusty or even a short bolt but, he needs 5/8 x 20tpi or 16 x 1.25 instead of 5/8 x 18tpi or 16 x 1.5
You got any idea who may carry em in that size 20tpi? If he finds them I may grab some myself for future projects.
Old 11-11-2014 | 07:39 PM
dusty1's Avatar
I will find some
I need some too
Old 11-11-2014 | 10:22 PM
dusty1's Avatar
not ideal, but works....with some help
Through Bolt Gal M16x125 20qty | Better Hardware - Trade Quality Supplies At Lower Prices
stainless and galvy....all I could find in these.
thinking out loud: what is the muzzle on m14s/m1a? I think its 5/8 x 20 or maybe 24....can't remember and i'm in Houston, otherwise I would look. If same I may have something that works or at least a tap and die
Old 11-11-2014 | 10:56 PM
abran's Avatar
just use the SAI holes to inject nitrous
Old 11-12-2014 | 07:51 AM
Thanks dusty. anchor bolts. good find. I'll have to check around locally to see if any in that size. Would be easy enough to cut to length and grind a square head or a slot to run it in.
Maybe the op will see this before he welds his up.
Quick Reply: Plugging the SAI head holes?
