PO141
Old Aug 24, 2007 | 10:34 PM
ajh's Avatar
ajh
Default PO141
Just lookng through the service manual I only see one O2 sensor, the Heated O2 Sensor, the OBDII code says Bank 1 Sensor 2 though, just want to confirm it's the obvious one before I order a new one.
Old Aug 25, 2007 | 06:48 AM
Default RE: PO141
How many miles on your truck, if you are approaching 100,000 miles then you want to buy all fourto get the full benefit of the 02's performance. Atlantic British has them on sale right now for $59.
Old Aug 25, 2007 | 09:10 AM
ajh's Avatar
ajh
Default RE: PO141
Nowhere near, only 60K KM. I am finding most of the 100K KM service items needed doing though, harsh environment wear I suppose. I've done too much work this month though, I can probably fix the one bad one but not doing any more until Oct/Nov at least.
Old Aug 25, 2007 | 11:14 AM
Darover's Avatar
Default RE: PO141
Changed mine last febuary. Ottawa Land Rover sells them for about $80.00 each. I'm trying to stay as away as possible from the dealer, but for critical parts like this, I felt more comfortable getting the o.e.m ones.
So yours would be the rear sensor. Make sure you get one for the rear, cause the front ones have shorter wiring that won't reach the plug-in.
Old Aug 25, 2007 | 12:57 PM
ajh's Avatar
ajh
Default RE: PO141
I'm assuming there are two rear sensors? Any idea which is which? It's probably in the service manual somewhere, but I haven't found it yet.
Old Aug 25, 2007 | 01:28 PM
Darover's Avatar
Default RE: PO141
Yep, 2 fronts before each cats, and 2 rearsafter each cats. 90% sure that bank 1 is the driver's side, and 100% sure that sensor 2 is the second one in the line, thus the aft cat one. Mine had both failed at the same time, so I had gotten bank1 sensor 2 and bank 2 sensor 2. The later, if I remember right was P0161. So by changing both I couldn't get them wrong. All this because I had the brilliant idea of trying Acetone in the gas. 10 kms later, they were cooked.
Old Aug 25, 2007 | 09:57 PM
ajh's Avatar
ajh
Default RE: PO141
OK, thanks. I'm ust going to replace things as they fail for now since I'm probably doing a block-back exhaust upgrade next year anyway.
Old Aug 26, 2007 | 07:55 AM
Default RE: PO141
So, bank, #2 is the drivers side rear 02 sensor.
