Pollen Filter Hack
Old Jan 23, 2022 | 04:25 PM
cvhyatt's Avatar
Default Pollen Filter Hack
Just thought I would share this with folks.
Grabbed some cutable filter material from Home Depot (not a new idea). As I was putting it in, I realized the clips were not sufficient to hold the filter in place. So I trimmed up some of the filter frame to fit and snapped it in place. Seems like it does a more secure job holding the filter in place.
Finished product
Old Jan 23, 2022 | 07:04 PM
greisinb's Avatar
Thanks for posting, my original filter has long since disintegrated to dust and I have a few clips missing. I shudder to think how much stuff has been sucked in to my blower motor since the last time I cleaned it out. Might have to implement this ASAP after I find a way to replace the missing clips somehow (probably 3D print them).
Old Jan 23, 2022 | 07:14 PM
cvhyatt's Avatar
With this mod, you don’t need any clips. The plastic frame holds everything in on its own.
Old Jan 23, 2022 | 09:26 PM
greisinb's Avatar
Even better!
Old Jan 24, 2022 | 09:46 AM
jbullard's Avatar
Nice hack! Did you find anything at home depot that will replace my shattered windshield cowl?
Old Jan 24, 2022 | 11:07 AM
cvhyatt's Avatar
Yes! Did my repairs with JB Weld Plastic Bonder. Once cured, I sanded and polished with plastic polish. Not perfect, bit it works effectively.
Check out the following links:
https://landroverforums.com/forum/di...53/#post805809
https://landroverforums.com/forum/di...56/#post808706
Old Jan 24, 2022 | 11:30 AM
jbullard's Avatar
I may have to give that a try! Mine is cracked in a few more places than yours, but it might still work. Yours looks good after the polishing! I also learned about the dash hold down kit via your links which I hadn't seen before and will have to give a go in the future.
Old Jan 24, 2022 | 03:55 PM
Brandon318's Avatar
Just curious, the actual filter isn't that expensive ($25 at Atlantic British) why the hack?
Old Jan 24, 2022 | 03:56 PM
Brandon318's Avatar
Anytime I go to a junked Disco, I take clips. See if any yards have a disco lying around in your area.
Old Jan 24, 2022 | 03:59 PM
cvhyatt's Avatar
$12 for this filter material and it can be had at any Walmart, Lowes or Home Depot. Also, the $12 buys you a full year's worth of filter material. But you're right - not so much a cost issue - more of a convenience item.
