Positive Battery cable gauge
Hello does anyone know the gauge of the the 2 positive battery leads? the previous ower butchered the terminals off and put a top post and side mount terminal on the leads so I want to replace the terminals.
Thanks.
Sorry it's a 2000 Disco 2 incase the leads changed year to year
Thanks.
Thanks.
Thanks.
The gauges of the battery cables are metric -
40mm² for the battery to starter motor cable
30mm² for the battery to engine compartment fuse box cable
40mm² for the battery earth cable
The factory battery clamps are cr@p and work loose/stop tightening-up.
I replaced mine with copper lugs crimped on to the cables, and used battery clamps with an M10 threaded post.
Lives -
![Name: DSC03128a.jpg
Size: 709.0 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38621d1501370404-positive-battery-cable-gauge-dsc03128a.jpg)
Earth -
![Name: DSC03127a.jpg
Size: 780.9 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38622d1501370404-positive-battery-cable-gauge-dsc03127a.jpg)
Both -
![Name: DSC03126a.jpg
Size: 753.8 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38623d1501370404-positive-battery-cable-gauge-dsc03126a.jpg)
With covers -
![Name: DSC03125a.jpg
Size: 758.1 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38624d1501370404-positive-battery-cable-gauge-dsc03125a.jpg)
![Name: Battery-earth.jpg
Size: 21.5 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38619d1501370379-positive-battery-cable-gauge-battery-earth.jpg)
Otherwise the cables are going to end up looking like this
![Name: corrosion1.jpg
Size: 26.0 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38620d1501370379-positive-battery-cable-gauge-corrosion1.jpg)
For the OP, here's an AWG to mm² conversion chart: AWG to square mm Wire Gauge Conversion
I already have
![](http://img.photobucket.com/albums/v686/paulmc0308/Misc/icon_thumbup.gif)
I took those pictures (almost 2 years ago), just after I'd changed the terminals.
They now have adhesive lined heatshrink over the cable entry into each lug (just as you've pictured), as well as a new Genuine Land Rover battery.
EDIT: Pictures taken 13th March 2014
![Name: DSC04336a.jpg
Size: 841.7 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38615d1501370379-positive-battery-cable-gauge-dsc04336a.jpg)
![Name: DSC04337a.jpg
Size: 846.0 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38616d1501370379-positive-battery-cable-gauge-dsc04337a.jpg)
![Name: DSC04338a.jpg
Size: 717.3 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38617d1501370379-positive-battery-cable-gauge-dsc04338a.jpg)
![Name: DSC04339a.jpg
Size: 744.9 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38618d1501370379-positive-battery-cable-gauge-dsc04339a.jpg)
Last edited by PaulMc; 03-13-2014 at 01:12 PM. Reason: Added pictures - 13th March 2014
Excellent,thank you all for the info, it's exactly what I needed. While I have your attention, I'm in the process of putting her back together after a head gasket installation ( I didn't disassemble it, I bought it like this) there are 2 green wires back near the firewall with eyelits on them, I assume they are ground wires, where do they go? also a yellow wire with an eyelit up near the alternator mount, where does it go? thanks for your help!
Earth (ground) wires are Black, the wires you've described don't sound like factory wiring.
Can you trace them back to where they originate?
You'll need to burn them to a CD or create a virtual drive with something like Daemon Tools and mount the images.
http://www.green-oval.com/data/lr/rave01.iso
![Name: Rave_01.jpg
Size: 14.5 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38612d1501370379-positive-battery-cable-gauge-rave_01.jpg)
http://www.green-oval.com/data/lr/rave02.iso
![Name: Rave_02.jpg
Size: 12.2 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38613d1501370379-positive-battery-cable-gauge-rave_02.jpg)
http://www.green-oval.com/data/lr/rave03.iso
![Name: Rave_03.jpg
Size: 21.1 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/38614d1501370379-positive-battery-cable-gauge-rave_03.jpg)
Thanks
sorry my windows computer flipped my iphone pictures like it always does.
