Is it possible to replace just the ball joints on the tie rod bar?
Old Apr 10, 2013 | 10:42 AM
me 2's Avatar
Default Is it possible to replace just the ball joints on the tie rod bar?
Just curious if there is a ball joint for the tie rod bar?
Old Apr 10, 2013 | 10:53 AM
drowssap's Avatar
do you mean replace the tie rod on the end of your drag link?
ROD & FIXED BALL JOINT DISCOVERY II TRACK ROD, RNH074, QFS000040 - Land Rover Parts | Rovers North
Attached Thumbnails Is it possible to replace just the ball joints on the tie rod bar?-plh072.jpg
Old Apr 10, 2013 | 11:14 AM
me 2's Avatar
Default stuff
Yeah, but instead of the whole bar can you just replace the ball joint?
Old Apr 10, 2013 | 11:20 AM
drowssap's Avatar
if you look at the picture above you can see that one end (with the threads) can be replaced and one can not. If you do need to replace the track rod/ drag link because it is the end that can not be replaced? most of the after market rod have replaceable tie rods on both ends.
Old Apr 10, 2013 | 11:26 AM
me 2's Avatar
Default stuff
Yeah, both ball joints are in bad shape.
Old Apr 10, 2013 | 11:47 AM
drowssap's Avatar
check out this post from yesterday;
https://landroverforums.com/forum/di...rod-kit-58269/
Eric at AB has a stock replacement for 169.00
http://www.roverparts.com/Parts/QHG000050.cfm
Old Apr 10, 2013 | 12:42 PM
If you are referring to the actual tie rod, only the short end can be replaced, if the long end is bad you must replace the entire long end. As for the drag link, yes either end can be replaced.
Old Apr 10, 2013 | 09:08 PM
TRIARII's Avatar
Now Im getting confused again because afew other members said you can replace both tie rod ends without the need of replacing the entire rod. Which is it guys? Not that it matters to much for me because I already ordered a new kit, but it would be useful info. Would be nice if everyone on here could agree on something to lol.
Old Apr 10, 2013 | 10:04 PM
It all depends on the tie rod and track rod you have, some had replaceable ends, others did not.
Here is the parts diagram, it lists both kinds.
Land Rover Discovery II Steering Parts Available from RoversNorth.com - Land Rover Parts | Rovers North
Old Jun 13, 2013 | 03:26 PM
me 2's Avatar
Default stuff
Looks like Im going to need front and rear rods then plus ball joints.
Charlie_V
Aug 14, 2015 11:18 PM
Clunker
May 9, 2011 08:16 PM
mx930
Nov 7, 2010 06:39 PM
cbwhitley
May 29, 2007 06:44 PM
jcw
Oct 27, 2006 08:26 PM
