Post filter change issues on 2003 Discovery
Post transmission filter change issues on 2003 Discovery
Here goes...
thought I would do some maintenance on my 2003 transmission. I had done a filter and fluid change on my 2001 so I thought it would be a breeze. Not so fast lol.
did the change with a filter and gaskets for AB. My 1-2 shift and 2-3 got strange. The gear will hold much longer than normal before shifting up at medium throttle. I thought maybe I was low on fluid so go back to flat ground with a warm truck to check and when I opened the fill plug maybe 1/3 of a quart came out. I should say fluid looked good that came out initially as well as every time since. Not sure why fluid came out cause I was very diligent with the change and followed the AB video to a T. Ran pretty well after that started delay shifting and even hard shifts. I thought maybe I missed one of the orings or somehow it did not sit right. So I got the filter kit from NAPA and did another drain and filter replacement. The AB filters orings were fine. The Napa filter seemed heavier than the AB. Went with Valvoline synthetic AFT. Same issues. I have a friend that flashed the tcu and it ran great for about 19 miles. So smooth but then fell back into the same story. Recently it has started to bang 2x when slowing to a stop at about 5mph. I removed the rear driveshaft to see if that was the issue then reinstalled and removed the front driveshaft. No change although the bang noise is less pronounced with the front driveshaft removed. I can replace the trans but it kind of seems almost electronic more than mechanical (because of the flash) thoughts?
How many miles were on trans and when was last fluid/filter change? Was there a lot of clutch plate material in pan?
Not that strange to have trans issues after a fluid/filter change, especially, if it has been well over a hundred K since the last one. Normally, if l do not know age of fluid and filter and trans is shifting/operating fine in advance...l causion on the side of error...drop fluid, only, refill using proper sequence, drive it for a few weeks, then drop pan and change fluid and filter second time.
Normally, you'd see/feel slippage after a fluid/filter change that was prolonged to the point of trans fluid being the only thing left in the trans that had fiction qualities. With yours, holding in gear longer and banging in between shifts...almost like you got a lot of debris lodged in valve body.
