Power seat not working
Old Mar 18, 2018 | 07:57 PM
Jaredhidden's Avatar
Default Power seat not working
Hey guys, my drivers seat isn’t moving in any direction, but I can hear the motor working and the heated seats work, any thoughts?
Old Mar 18, 2018 | 09:11 PM
Friday Night Disco's Avatar
Can you look under the seat and tell if anything is moving?
Old Mar 19, 2018 | 06:33 AM
Yes, nothing is moving, replaced all fuses- can hear a hum of a motor but that’s it,
Old Mar 19, 2018 | 09:47 AM
jamestfl's Avatar
Could be the track needs silicone, but had the same problem with mine. Click and hum but no movement. Replaced motors, all good. Not a tough project, a bit tedious.
Old Mar 19, 2018 | 10:09 AM
OffroadFrance's Avatar
You may find something has been dropped down the side of the seat jamming the motor drive, if you're lucky, otherwise it sounds like the motor has expired.
Old Apr 20, 2018 | 04:44 PM
Disco_Dion17's Avatar
Could the gear bar be stripped? If the motor is working, but nothing is moving then it is either stuck or something isn't grabbing while the motor turns.
I am having a somewhat similar issue, except I can not hear the motor working. The seat will tilt, but it won't move back and forth. Anyone know where I can buy a new motor for the front-to-back adjusting function?
Old May 29, 2018 | 08:13 AM
jstorz's Avatar
Had a similar issue, turned out a passenger had kicked the big connector that runs from the switch to under the seat (it was covered by a protective wrap). Connector on this disco didn't lock very well and had separated about 1/8"-1/4". Gave me intermittent operation of tilt, but no operation up/down, back/forward or lumbar. Cleaned it, put it back together, wrapped it with a little tape, all good. (of course this was after hours of tracing the circuit, cleaning the switches, etc.)
Jeffrey
Old May 29, 2018 | 10:22 AM
jamestfl's Avatar
^^^ all good suggestions. Mine ended up needing replacement.
Old Jul 9, 2022 | 05:35 PM
Woodman's Avatar
Default 2010 Range Rover Sport Passenger seat not movies forw and back
Jeffrey
is there a seat repair Manuel out in the world somewhere? Where is the fuse box for the seats?
bigugly82
Jan 11, 2024 08:10 AM
tsuyoi
Sep 22, 2020 10:37 AM
sleepy1525
Mar 12, 2015 03:32 PM
Rover_Hokie
Oct 17, 2013 01:46 PM
Just For Fun
Aug 16, 2013 09:27 AM
