Power Steering Delete; 1.5-2 MPG Increase
You don't want the box full of fluid; only a very small amount. If the box is full then steering will be more difficult and the box doesn't need to be full to prevent wear.
Did i miss the part if you looped a line from the rack?
That's true when using a manual steering box, but when using a PS steering box you want it empty because the fluid moving through the small valleys and pores inside the power box will add quite a bit of resistance. It makes a huge difference between a full steering box and a drained one.
There shouldn't be a ton of wear on it anyway. There is still a fluid film inside and it's not like there are any constantly moving or rotating parts like in the drivetrain.
And there is no rack. There's a steering box and the two wheels are connected with a tie rod instead of there being a central rack that connects to each wheel on either side.
Like I said, Frank, I know this one isn't going to be for most people.
In all honesty, I'm on a shoestring budget right now. That 17% increase is an extra $70/month that I could really use right now. And I can't just drive a more fuel efficient vehicle because I use her for all her capabilities for work.
France, it was really tight before I drained the steering box. Once I had it drained it wasn't bad!
