..:: The power steering fluid situation ::..
Old 05-02-2022 | 01:19 PM
adolfojbonilla's Avatar
Default ..:: The power steering fluid situation ::..
Hello All,
Looking for some clarity since couldn't find any on RAVE ...what is the total fluid needed after Power Steering Pump replacement, just trying to determine how many quarts to buy to ensure max fill.
The other question, which is the Power Steering fluid of choice? I've read many mentioned the Red Valvoline bottle, what are your thoughts? Thanks.
Old 05-02-2022 | 01:28 PM
Motorhead1's Avatar
I've always just used Power Steering Fluid. Nothing special.
Old 05-02-2022 | 01:37 PM
...thanks, but which brand in particular?
Old 05-02-2022 | 01:50 PM
andino's Avatar
I use Pentosin CHF 11s or 202
cvhyatt (05-02-2022)
Old 05-02-2022 | 01:59 PM
cvhyatt's Avatar
+1 on the Pentosin. I've tried a generic power steering fluid but went back to the Pentosin. Its pretty expensive but for me it made a bid difference.
Old 05-02-2022 | 08:08 PM
gecko951's Avatar
I have used Pentosin in the past but recently filled with GM Fluid 12345867 Cold Climate Power Steering Fluid and its been working well for me!
Amazon Amazon
Old 05-03-2022 | 02:37 AM
Alex_M's Avatar
I've used everything from 15w40 to Transmission Fluid and a few things in-between. In fact ATF is my go to. Other users have noticed some difference using "other than stock" fluids, but I have not. Very happy with the performance of ATF and sometimes thickening the fluid a bit with some 15w40 will help quiet a noisy PS pump.
Old 05-03-2022 | 06:58 AM
mollusc's Avatar
I noticed a huge improvement in steering feel as well as a reduction in noise after switching to Pentosin CHF. But it's damn expensive.
Old 05-03-2022 | 01:12 PM
redrover75's Avatar
The Lucas leak stop is a good add in if you have any random leaks. I have used the cheap stuff with no issues.
Old 05-03-2022 | 02:27 PM
Harvlr's Avatar
I think using the Stop Leak will give your PS pump and Steering box a life expectancy. I believe it swells the seals and will stop or slow the leak for a time, but rapidly increase the wear on your seals.
Quick Reply: ..:: The power steering fluid situation ::..
