Power Steering flush question
Old Feb 17, 2011 | 10:01 AM
reddevildemo's Avatar
Question Power Steering flush question
I have been searching for a day and have not ran into anything talking about my issue.
I had a leak coming from the lower hose, runs from Res to bottom of pump. The factory clamp came apart at pump. I replaced the hose and clamps on both ends. I refilled and followed the instructions in the wave manual on flushing.
I took one complete quart to fill res after hose change. I have since used 2 more quarts during the flushing procedure.
The issue I am having is, I get fluid out of the bleed screw while turning in one direction but nothing while turning in the other, my res is foaming to the point that it will come out of the cap opening.
I used LR fluid @ $14 a quart !!
My question is does it take this long, is it normal for the fluid to only come out while turning in one direction and not the other?
Oh, the pump groans as well no matter which direction it turns in.
Thanks for all the help.
Old Feb 17, 2011 | 11:08 AM
Bundu's Avatar
Banned
Do you get bubbles in the return when the wheels are straight?
It could be sucking in air at the hose clamps that you replaced.
Old Feb 17, 2011 | 11:28 AM
There was always a little churning in the tank looks to be the same that way. Pump makes no noise unless actually turning wheels, once you atop turning no matter what the position they are in it stops whining.
I rechecked clamps, no leakage found anywhere. I pressure washed under carrage to get rid of all the oil spilled while bleeding too.
wannabe
Jan 24, 2011 10:42 AM
tsuami1
Jul 4, 2010 05:25 PM
Baylink
Nov 7, 2009 08:49 AM
tunernewb92
Jun 23, 2009 04:44 PM
bradbenz
Sep 8, 2007 08:06 AM
