Power steering noise when cold.
Old Jan 2, 2012 | 01:27 PM
  #21
Hay's Avatar
Hay
Exactly, it's usually just the gasket. Not sure about using JB weld. I used a high quality sheet gasket material and made my own gasket. Any new pump is probably going to have the same crappy gasket that won't last long. RTV doesn't work. Lots of threads on this topic. Save some money and just replace the gasket.
Old Jan 2, 2012 | 03:40 PM
  #22
94svt50's Avatar
I used jb weld because I only wanted to do this once. If it leaks I will never be able to get the case open so I will just throw on a new pump if that was to happen.
Old Jan 2, 2012 | 09:06 PM
  #23
04BluDisco's Avatar
not to high-jack, but I have a similiar situation, but it's more of a chirping from the front of the motor... I HAVE tried narrowing it down, but seems to be from around the location of the water pump... It chirps on start up when cold (in a garage, so about 60 degrees), then quiets down after about 30 seconds...
I have a new oil pump, new water pump, timing gears, etc., and was planning on replacing next weekend. So, my question is, has anyone else had a similiar experience where the water pump was chirping on start-up... and does it stop when it's replaced?
.. or oil pump, for that matter...
Thanks...
Old Jan 6, 2012 | 05:52 PM
  #24
jrkstore43's Avatar
Hey gang,
So it really looks like the hose is the issue on my DII. I have a new one and intend on replacing it tomorrow. Obviously I will need to replace a bunch of power steering fluid after the job and I suppose I need to bleed the system afterwards? Is it really just as simple as loosening the bleeder screw similar to bleeding the brakes? Any additional words of advice?
Thanks.
Old Jan 6, 2012 | 09:48 PM
  #25
DiscoRover007's Avatar
You can actually replace the return hose with a cut to fit hose from autozone and save yourself about 50 bucks. Plus you can also get some universal gasket material at autozone and use that to make the new steering pump gasket. I did this early last year and it's been working fine.
Old Jan 8, 2012 | 09:31 AM
  #26
04BluDisco's Avatar
Do you have any pictures you can take of the removal of the parts of the steering pump/gasket creation process? thanks
mattmo78
Nov 21, 2013 01:23 PM
pkppunk
Jan 26, 2013 07:05 PM
orionpaxx
Nov 7, 2011 10:07 PM
Testpilotb
Dec 14, 2009 11:16 AM
Robbo
Jun 15, 2005 05:03 AM
