precision #617-ball kit
looking at rock auto parts online about the centering ball kit for my 2001 disco....My vehicle is not listed as applicable to this part on their website...I called there and they just read me the applicable vehicles for this part. Is this the correct part for my front driveshaft??????
Also, that's just for the double cardon side only(the infamous problem area). If, by chance, you want to change all the u-joints on the front driveshaft, while it is off, you need a third #344 for the other end.
ORIGINAL: PalmettoDisco
It is good to replace both the other 2 u-joints especially if you have some long miles on your truck, also check and replace the rotoflex if needed and grease both flex shafts.
ORIGINAL: Disco Mike
A new u-joint is going to be better than a 50,000 mile used one (even properly maintained). A simple u-joint is easy and cheap to replace (relative to the double cardon). It might not be necessary but since you already have the driveshaft off, it's something to consider.
