Premium vs. Regular Unleaded
Old Aug 12, 2007 | 10:03 PM
mordor110's Avatar
Default RE: Premium vs. Regular Unleaded
I put in a bottle of the Lucas and felt a smalldifference but not much. Last fill up I threw in a bottle of the Sea Foam and can already feel a noticable difference with only 10 miles on this tankful.
Old Aug 13, 2007 | 08:09 AM
khandrh's Avatar
Nick,
Did you just put the can of seafoam into your gas tank when you filled it up.. Did it give any smoke...
Old Aug 13, 2007 | 08:15 AM
The real improvement from SeaFoam comes when you use it as a decarboning agent.
Old Aug 13, 2007 | 04:29 PM
S4poor's Avatar
I agree. Seafoam works best when used in all three locations. Gas tank, crank case, and vacuum system.
FYI: Driving it with Seafoam in any of those locations is a bad idea.
Old Aug 13, 2007 | 04:38 PM
98roverguy's Avatar
ORIGINAL: S4poor
Minus the gas tank.[sm=burnout.gif]
Old Aug 13, 2007 | 05:11 PM
okdiscoguy's Avatar
ORIGINAL: S4poor
Whats wrong with driving it after the induction cleaning? I let it soak, fired it up and drove around the block to dissapate the smoke. I agree not to drive it with it in the crank case, but in the gas tank and induction, I don't see a problem.
Old Aug 13, 2007 | 05:24 PM
S4poor's Avatar
ORIGINAL: okdiscoguy
ORIGINAL: S4poor
Correct, if it's just in the gas tank it's not as big of a deal. Though I would still not drive it, but that's just me
Old Aug 14, 2007 | 09:18 AM
khandrh's Avatar
I know that I need do do an engine flush, but in the meantimeI am going to be traveling with the family ( a 3 1/2 hr ride each way). I was thinking of putting in a can of sea foam just toclean things out alittle, in hopes to get a couple of more miles a gallon on the trip.Should I use the SeaFoam or the techron..
Old Aug 14, 2007 | 10:05 AM
SeaFoam, Techtron or spend the big $$$'s and buy a can of B&G's 44K, the best by far.
Either way, your engine will come out cleaner and running better.
Old Aug 14, 2007 | 10:08 AM
khandrh's Avatar
Do they sell B&G 44k at AutoZone etc.
