price to mount and balance tires?
Old Dec 17, 2008 | 08:42 PM
discoxd's Avatar
Default price to mount and balance tires?
anyone know about what it will cost to have 5 tires mounted and balanced? i am sending my cousin to the tire shop tomorrow to have the mud terrains i bought from a friend put on the rover... i'm just not sure of about how much money i should send with her...
Old Dec 17, 2008 | 08:56 PM
Default RE: price to mount and balance tires?
Well when I had the snow tires mounted on my wifes car I took the tires off teh car and brought the snows and the rims with the summer tires and they charged me $10 per tire plus $2 per valve stem.
The most expensive that I found was $20 per tire.
That was with is 16" rim, anything larger than that they will charge you more. (just a FYI)
And MAKE SURE that they DO NOT use the impact wrench to put the rims back on your truck.
They MUST use your tire tool.
Old Dec 17, 2008 | 10:46 PM
discoxd's Avatar
i will send the impact directions along but i cant be there to supervise... i'm sending my cousin to do it for my while i am at work tomorrow... hopefully they can read because i am sending a note with instructions for the tire place... i know the usual reasons not to use an impact wrench, like the tire may not seat properly and severely overtorquing the lugnuts, but is there any "rover specific" reason not to?
Old Dec 18, 2008 | 03:00 AM
Disco2Guy's Avatar
Yeah, LR charges $20/lug nut. Tell them if they don't want to pay for a new set, follow your instructions.
Old Dec 18, 2008 | 10:06 AM
You need to go buy a socket for your wheels and keep it in the truck so someone doesn't use the wrong size and take out your lug nuts, also, have the final torque set by hand with a torque wrench only, I think your's need to be set at 95 or 100 foot pounds of torque.
Air pressure should be 35/40 or 40/40 no more no less.
Enjoy the new tires.
Old Dec 18, 2008 | 11:19 AM
discoxd's Avatar
yeah change of plans... no one will mount used tires... so saturday i get to do it myself and then i will just have to take them to get balanced... serious PIA!!!
Old Dec 18, 2008 | 11:40 AM
I have had used tires mounted before, not sure why you think you can't.
Old Dec 18, 2008 | 11:59 AM
discoxd's Avatar
called everyone... they all said they wont do it... "liability", but what they really meant to say was "just buy some new ones from us"... its ok though found a shop that'll do it so i am goin drop off the rover right now...
Old Dec 18, 2008 | 12:24 PM
lrd2's Avatar
i have a question last time i got my tires changed at firestone it looks like the used the impact gun because i got a flat the other day and i pretty much almost bent the tool to take off the lugs. Which they never came off i had to use 3 cans of fix a flat now are my lugs damaged or do i just need a gun to have them loosend up?
Old Dec 18, 2008 | 01:53 PM
discoxd's Avatar
get an impact socket that is the correct size (6 sided not 12 point) and a half inch drive breaker bar... if you need to put something longer on the breaker bar... if you still cannot get them off drive straight to where you got them put on and make them figure out what they did...
