Probably the coolest d2 I’ve ever seen
Old Mar 26, 2020 | 09:06 PM
Fastercat's Avatar
Default Probably the coolest d2 I’ve ever seen
This looks amazing. Wish I had the cash. I’d buy this in a second
Old Mar 26, 2020 | 10:12 PM
No Doubt's Avatar
Wild. How did he do the aftermarket steering wheel?
I ask because that steering wheel accepts a spacer for those who want it closer.
Old Mar 27, 2020 | 07:18 AM
XRAD's Avatar
The rebuilt Portal axles alone cost more than a used Disco......
But might have upgraded the engine to match the rest of the vehicle....
Old Mar 27, 2020 | 09:38 AM
whowa004's Avatar
I love the front bumper aside from some of the upper cage portions in the middle.
Old Mar 27, 2020 | 10:09 AM
TimInNova's Avatar
I guess he doesn't have to worry about leaking sunroof s
Old Mar 27, 2020 | 11:54 AM
mln01's Avatar
Greg Davis is local to me, here in the Charlotte area. The rear bumper he designed and sells for the DII is legendary in the DII community. A Google search will yield result on discoweb.com and probably here too.
Old Mar 27, 2020 | 12:42 PM
Banzai Jimmy's Avatar
From 2017, more info on this rig named Winston: https://www.pirate4x4.com/forum/land...ng-my-rig.html
Old Mar 28, 2020 | 07:37 PM
XRAD's Avatar
High volume long run production steering column shafts are often similar with measurements/spline pattern, so you can likely find a hub spacer. I had a Nardi spacer a few years ago for another vehicle. The key is that these are generally machined made for aftermarket steering wheels like Sparco, which have a six bolt pattern. They are not machined for the discovery wheel (which is currently held on by a nut, which will be used to mount the adapter). Second, the pass through wiring does not usually include the air bag or radio controls. Just the horn. So if you want a spacer and an aftermarket steering wheel, there is someone out there selling what you need.......
And I agree with you. I would like my wheel closer to me...
Old Mar 28, 2020 | 10:00 PM
Brandon318's Avatar
I hate this thing so much. At a certain point (that was exceeded) it just isn't a D2 anymore.
Old Mar 29, 2020 | 02:05 PM
Brandon318's Avatar
Originally Posted by XRAD
I think it's interesting that out of all the Disco parts to keep, he kept the engine and drive-train.......It's like a reverse Frankenstein build....
Haha, so true.
