problem 4.6l discoII
SALTW16443A816180
it does not knock right at start up but starts shortly after no lights come on nor does it run hot i think the knock is still there after reving enging but it changes pitch to a higher one thanks and please help
TECHNICAL ALERT
March 14, 2003 TA03 1201
NAS US Only Cda Only
ATTENTION: Service Manager Service Advisor Technician
X
2003 Discovery Series II Oil Pump Failures
Vehicles Affected
Discovery Series II (LT) VIN 3A771801 - 3A808362
Situation
Oil pump failures on 2003 Discovery Series II vehicles may be the result of a
manufacturing error. Locating dowel pins may be slightly misaligned permitting
assembly of the oil pump to the engine block, but placing stress on the pump housing
which can ultimately lead to leakage or failure.
Resolution:
Whenever an oil pump failure is encountered on vehicles within the above VIN range
the only effective repair currently available is replacement of the complete engine
assembly including the front cover/oil pump manufactured to the latest tolerances.
Use the following components to affect a repair:
LBB112301 4.6 Engine assembly LEV
LBB111461 4.6 Engine assembly NON-LEV
You are out of the range. What weight oil are you running, and do the test Mike suggested. Cold and at 2K RPM
X
Vehicles Affected
Situation
Resolution:
