problem 4.6l discoII
Old 02-04-2010, 02:26 PM
storyball's Avatar
7th Gear
ok thanks i guess thats a relief im running 10w in it but another guy told me to run rotella 15 40 what do yall suggest???? thanks
Old 02-04-2010, 04:45 PM
okdiscoguy's Avatar
do you mean 10W40? I wouldn't switch to 15W40. Get your pressure tested again. Just because you aren't in the range doesn't mean your oil pump is good.
Old 02-17-2010, 04:03 PM
storyball's Avatar
7th Gear
Default Proper Oil pressure
Can anyone tell me the proper oil pressure for the 4.6 motor at a cold start and at a 2000 rpm idle for an 03 disco II thanks a bunch
Old 02-17-2010, 04:16 PM
lipadj46's Avatar
There is not really much of a difference between 15w40 and 10w40 besides 15w40 in general being better tougher oils that shear less (less viscosity improvers needed). They are the same viscosity at operating temps and not that different at startup temps.
As far as cold idle pressure someone can double check me but 15psi is fine. I am getting all my oil pressure and temp gauges tomorrow so I will see for myself.
Old 02-17-2010, 04:19 PM
okdiscoguy's Avatar
2K is in the 40's I think around 20 at idle when hot...
mach5288
04-26-2007 09:22 PM
Discofan
11-29-2005 12:32 AM
sclarkie
08-09-2005 04:01 PM
BamaLandRover
07-13-2005 12:20 AM
davidc99
06-01-2005 04:05 PM
Quick Reply: problem 4.6l discoII
