Sponsored by: CARiD
DiscoII breaks problem.
Old Nov 28, 2005 | 11:00 PM
Discofan's Avatar
Default DiscoII breaks problem.
Hi! Just wandering if someone had same problem or have an answer to it.
I changed front break pads on my DiscoveryII, 2000 about 15kMi ago. When I was doing rotation on my tires (thank God!) I found that the passenger side front pads almost gone, but driver front side is still like new. Caliper, collapsed hose or maybe need bleeding????
Also, is it possible to find just plastic body for the driver side door mirror? Mine got hit with the stone, motor still working, just need body. Is any other models are the same. I saw lots of them on Fleebay from GB, but can't figure out their models 200, 400 ets...
Please help!
Thanx!!!!!
Old Nov 29, 2005 | 12:32 AM
mikemeyer0's Avatar
Default RE: DiscoII breaks problem.
sounds like a good bleeding would help that out, check you lines and the caliper, mke sure the caliper operates smoothley. plug the line on the one thats working and try the breaks, see if it works.
butterworks
Apr 22, 2009 10:44 PM
andrewmcoffin
Mar 1, 2009 02:57 PM
feitinger
Jan 27, 2009 02:43 PM
barryd
Nov 6, 2005 07:10 PM
DIMISA1977
May 6, 2005 04:22 PM
