Problem with Brake Light Switch
Hello:
I have a 2000 Discovery II. the other day i got in the car and couldn't shift out of park. figured out it was the brake light switch. I jumped the connections with a paper clip and got her going. Brake lights stay on all the time but at least the thing will drive.
I ordered the replacement switch from atlantic british. its the "new style" with the wire bundle that connects to the original electrical connector and then to the switch.
I popped it in and it did not resolve the problem. With the new switch in i get no brake lights and can't shift out of park.
Other than the switch being defective, is there anything else that might be the problem?
Also, is there a common switch that I might find at the local autozone that would be worth a try? None of the chains stock the one for the LR.
thanks.
Matt
thanks.
Matt
i only ask the stupid question, because i was stupid enough to do it, did you install the switch back on completely before checking to see if it work? I didn't realize how the brack switch worked (brake pedal depressed, letting plunger come out, causing light to come on) so i tried checking before i completely installed it back on....
herblatham
01-28-2010 03:29 PM
angasreid
11-16-2006 11:40 AM
