problem - still running hotter than normal
Old Feb 11, 2015 | 06:12 PM
OffroadFrance's Avatar
Originally Posted by tdmadlem
don't have electrical fan for A/C; viscous fan clutch has some drag when cold, but today I checked it when engine at 194 degrees -- felt very loose -- very little drag; shouldn't the clutch have more drag when hot than when cold?
guess I need to replace fan clutch to try this solution'
The VC should be tightish at start up then slacken off at working temperature then get progressively tighter at higher temperatures and lock almost solid at max temperature but what that is in farenheit on a V8 I haven't a clue.
Old Feb 11, 2015 | 07:07 PM
dusty1's Avatar
195...should be lock up...me thinks
Old Feb 14, 2015 | 11:34 AM
tdmadlem's Avatar
thanks much to all for the advice - have ordered cooling fan clutch and a/c electric condenser fan -- should be here middle of next week; will keep posted on results -- after testing per the instructions I've received here I am very confident that the cooling fan with proper lock-up operation will solve the high heat issue; thanks again to all!
Old Feb 15, 2015 | 03:26 PM
me6067's Avatar
I had some similar issues with my truck this fall... To this day my electric fan does not work as it is seized and have yet to replace it. Long story short my truck was getting into high temps very fast and I too have a new rad, and grey thermostat and so on. Turn out it was my coolant temp sensor that was running about 40 deg hotter then actual. Best way to check is to use a code reader that can view ambiant air temp and coolant sensor temp when the truck is off and cold and they should be relatively the same.
Even though my electric fan is seized (will change very shortly) I am still getting good temps according to my ultra gauge. 188 to 192 on the highway and 190 to 195 in the city.
DiscoDubs
Jul 25, 2016 07:25 PM
Moses7
Apr 17, 2013 07:00 AM
mossmanxjt
Nov 11, 2012 06:38 AM
moomoo
Aug 7, 2011 10:00 PM
lipadj46
Jul 21, 2009 01:51 AM
