Problems discovery 2 automat
Old 04-17-2022, 10:54 AM
dino7's Avatar
Default Problems discovery 2 automat
Hello. I have a problem with my Discovery-2 As I was driving and suddenly stopped as if the lever went to the parking lot. Some ideas of what may have happened.
Old 04-17-2022, 11:42 AM
Harvlr's Avatar
You’ll have to explain that in way more detail. You were driving and the vehicle suddenly stopped, as if the drive train seized up?
Old 04-17-2022, 01:27 PM
dino7's Avatar
Yes, something like that happened. I removed the rear cardan shaft, but it still doesn't work. I also removed the front cardan shaft and then we pulled it home. Did something happen in the gears or in the transfer box. I have no explanation.
It turned out as if during the movement the lever went to the parking position and the jeep crashed. I turned off the bike and after 5 minutes started it I tried back and forth, but it only moves about 5-6 inches. So far I have not had any problems with the transmission. We do not have Discovery services here, so I ask you for advice on what to do. Thanks in advance.
Old 04-18-2022, 12:47 PM
jastutte's Avatar
assuming you are actually talking about a Land Rover Discovery 2 and not a jeep or bike, i'd check the fluid in the transfer case first.
if empty or really low, refill and try to drive it. though, it may have broken some internal gears if you ran dry on fluid.
adalton (04-19-2022)
Old 04-18-2022, 12:55 PM
dino7's Avatar
Thanks. Tomorrow we will check and write.
Old 04-18-2022, 02:15 PM
Harvlr's Avatar
Do you mean that while the vehicle was moving you put the transmission shift lever into the park position? If so, the problem will likely be inside your transmission.
Old 04-19-2022, 06:43 AM
adalton's Avatar
I am laughing so hard at this.
jastutte (04-20-2022)
Old 04-20-2022, 08:45 AM
dino7's Avatar
Hello. Today he found out that the transfer box was broken. Where can I find a second use one.
Old 04-20-2022, 10:18 AM
jastutte's Avatar
what is broken specifically?
your best bet is to source a used transfer case local to you. junkyard or a Land Rover specific breaker.
Old 04-21-2022, 12:04 AM
dino7's Avatar
Hello Will it be from a manual transmission or should I only search from an automatic.
Quick Reply: Problems discovery 2 automat
