Problems removing transmission
Old Jun 30, 2015 | 07:40 AM
superthrash1's Avatar
3rd Gear
Unhappy Problems removing transmission
New member here, new Discovery owner as well. My son purchased a 2002 DII last week with no forward gears. We have a replacement transmission and transfer case waiting to go in. I have removed all 14 mounting bolts and the torque converter bolts but I cant seem to get the trans separated from the engine?? It appears to be stuck right above where the starter mounts. I removed the starter for a better look, but that didnt really help much. We can get the case to come free on the bottom and other side but there is a holdup here. Is there a dowel or something in that spot that could be holding us back? Thanks in advance for any input and advice.
Old Jun 30, 2015 | 07:51 AM
drowssap's Avatar
there should be a dowel on each side just above the center line iirc
Old Jun 30, 2015 | 07:58 AM
3rd Gear
That would be in the right area. I am trying to remove it with t-case still intact, my next step is to remove it and see if that allows me to break it free.
Old Jul 1, 2015 | 06:05 AM
OffroadFrance's Avatar
Have you taken out all the bolts including the 2 hidden ones? Checkout the RAVE manual for bolt locations.
It is far easier to remove the autobox without the transfer box attached as the two gearboxes are over 100kgs
http://www.paddockspares.com/blog/zf...ked-questions/
From the photo you can see the locating dowels as well.
Résultats Google Recherche d'images correspondant à http://i212.photobucket.com/albums/cc10/bogchook/Rover/DSC07891resized_zps2d5fc335.jpg
Spencerfitch
Jul 18, 2010 09:38 PM
chris@wdainc.org
Oct 18, 2007 06:49 PM
dirtdude
Freelander
Jun 28, 2007 09:41 AM
cold_surfer
Mar 19, 2007 01:13 AM
