Project Discovery 2, need help with transfer case shifting
#21
No worries about the hi-jack lol. I cant wait to get my land rover going. I think I got a really good one. 99 with no sunroof, no ACE, and no SLS. On top of that the previous owner put on a TJM bumper, hella 400 lights, OME 2" lift, heated seat mod, cd changer, and rubber mats/ oem LR seat covers. Has some totally dry rotter bfg mt's with 90% tread. what a waste all that for $1100! so I decided that after pouring 4k into the motor ill have a solid discovery!
#22
Yeah I have no idea. I haven't found any spare bolts in my transmission pan and I've changed the filter a couple of times. Since it apparently does no harm let's call it a feature. Like a spare button on a shirt. The magnet will catch any metal shavings (hopefully there are none) so that's another feature. I don't recall a magnet just laying in mine but it actually sounds like a good idea. Maybe the last owner had some old time Rover mechanic in him or her.
#23
lol agreed. by the looks of it, most components in the AT are held on by more than 2 bolts so one missing one shouldn't be the end of the world.
Im becoming a rover mechanic quickly all i need to keep the motivation going is a little youtube and the gallery here. plus i sit in the drivers seat and pretent to be in the camel trophy.
#27
UPDATE:
as i suspected earlier, i placed the hi-n-lo shifter in the wrong area. Just a newbie mistake. In the process i removed the shift interlock cylinder and with no engine, and the transmission in neutral, i am able to shift into hi and lo by rolling the car back and forth a few inches. Glad that it wasnt something worse.
Thank you for everyones answers.
#28
How did you mis-place the shifter? the physical shifter, or the linkage? I'm getting into this pretty soon and I've been doing a lot of reading so that I can work around other guys' mistakes LOL
#29
please see this picture. note the shaft has a flat spot milled where the lever arm should go. I mistakenly put it at the end of the rod because it fit perfectly.
Diagram
Land Rover and Range Rover Picture by LandRoveris | 5158905 | LandRoverForums
Actual Transfer case
https://landroverforums.com/g/picture/5187288
#30
Diagram
Land Rover and Range Rover Picture by LandRoveris | 5187288 | LandRoverForums
Diagram
Corrigan
04-26-2013 02:38 PM
bosshogt
04-06-2010 11:56 PM
