Prop Shaft Changed - Didn't Fix Clicking
Old Aug 8, 2011 | 02:04 PM
charlestonwb's Avatar
Thanks again. Will take a look this weekend. With regard to play in the flange...should there be any movement if you tried to rotate the flange while the truck is in park? I'll check for overall tightness of the nut but curious about rotation. As I recall when I originally replaced the shaft, I was able to move it left/right a 1/4 inch or so.
thx
Old Aug 8, 2011 | 02:09 PM
dgi 07's Avatar
rotation wise, you should have a little. Think about it this way. When you have the car in park, you are still able to rock it back and forth a little, right? thas the rotation you are seeing. im talking about left to right and up and down movement.
Old Aug 8, 2011 | 07:21 PM
yep, a little play when rotating. I'll check the flange this weekend when I pull of the prop shaft again...fun. Thanks.
Old Aug 8, 2011 | 08:31 PM
dgi 07's Avatar
i know the pain of which you speak...I have to do the exact same thing next weekend. this weekend is dedicated to my 3 year old ball of energy niece..
Old Aug 8, 2011 | 09:54 PM
antichrist's Avatar
Originally Posted by charlestonwb
Just can't seem to think of a reason why it only does it when off the accelerator.
w
Because driveline components mesh slightly differently depending on whether they are pushing the car, or the car is pushing them.
Old Aug 9, 2011 | 09:31 AM
Makes sense on the push/pull. In fact, wife told me to "PUSH" the truck over a cliff! I'm filing for divorce today...
Thanks for all the help everyone.
Old Aug 9, 2011 | 01:43 PM
dgi 07's Avatar
completely understandable......i would too. Hope the judge gives you half her shtye!
Old Aug 9, 2011 | 01:48 PM
hilltoppersx's Avatar
have you checked the rotoflex? is it cracked?
Alex_M
Sep 7, 2024 05:21 PM
acg
Jan 25, 2015 11:08 PM
Jake1996D1
Nov 12, 2012 07:15 AM
Savannah Buzz
Aug 1, 2011 09:29 PM
domyo
Sep 25, 2008 12:19 PM
