Protect new windshield cowl / plenum cover?
Hey all, I have bit the bullet and purchased a genuine windshield cowl replacement (that big plastic cover under the wipers), and all the damn rubber parts that go with it. Let's say I want it to outlast the truck, how would you protect it?
I have thought about a UV protection clear coat or maybe a thin layer of epoxy covering the entire piece. What causes them to get brittle and crack apart to begin with? I have plenty of old autos with plastic bits on the outside that don't just fall apart like this stuff does.
I disagree with Externet. UV breaks down the OEM plastic causes it to become brittle. The thermal expansion from summer to winter does cause the cracking once it is brittle. I would recommend a coating if you want it to outlast the truck. You could use paint. I use the Duplicolor truck bed coating. Truck bed coatings have maximum UV protection as they are assumed to be parked outdoors at all times. You could have it professionally sprayed with Line-X or Rhino, they will hold up very well.
Ceramic coating or some sort of sealant would definitely protect it, however, I wouldn't worry about it. I got one out of a parts truck for $15 in perfect condition, I'd try looking in a Disco junkyard first. A guy I know that restores Discos says the new plastic ones don't fit as well as used ones.
Thanks for the input everyone. I am going to get a UV protectant spray, like a top coat clear-coat spray. Due to the garage being full the disco will be parked out in the sun the majority of the rest of its life. Extinct, your truck bed coating idea is a very intriguing idea... I may try a couple of test pieces first and see how that turns out. Weather was bad this weekend so this will be a next weekend project.
Thanks again all!
Thanks again all!
Yep extreme heat makes the plastic brittle. I've never seen a D2 in TX without issues. The windshield cowl is mounted directly behind the engine bay and it gets heated from the engine, and the sun. It's honestly a no win situation. I've been curious about the fiberglass made unit I've seen off of Ebay.
I bought one of the fiberglass cowls, fit nice. Does not have the factory vent grille for the cabin filter, you could obviously drill holes if you wanted. Strength, flexibility both better than an 18yo factory unit. Never handled a new OEM one so have no reference. Does not have the factory hooks.
There is another company now taking OEM parts and reenforcing them with fiberglass but I don't see any more aftermarket fiberglass parts anywhere.
sayeedA
02-07-2019 12:52 PM
krazzz
10-21-2009 07:34 AM
