Protect new windshield cowl / plenum cover?
Old Jan 9, 2021 | 11:04 AM
Tidder's Avatar
Default Protect new windshield cowl / plenum cover?
Hey all, I have bit the bullet and purchased a genuine windshield cowl replacement (that big plastic cover under the wipers), and all the damn rubber parts that go with it. Let's say I want it to outlast the truck, how would you protect it?
I have thought about a UV protection clear coat or maybe a thin layer of epoxy covering the entire piece. What causes them to get brittle and crack apart to begin with? I have plenty of old autos with plastic bits on the outside that don't just fall apart like this stuff does.
Old Jan 9, 2021 | 12:46 PM
Externet's Avatar
It will crack again as rain wets/puddles/stays in its underside and when that water freezes, ice expansion does it. If there was no way for the rain to stay under it or made of silicone, it would survive.
It is not the UV/heat/sun; is the freeze as far as I know.
Old Jan 9, 2021 | 07:40 PM
Extinct's Avatar
I disagree with Externet. UV breaks down the OEM plastic causes it to become brittle. The thermal expansion from summer to winter does cause the cracking once it is brittle. I would recommend a coating if you want it to outlast the truck. You could use paint. I use the Duplicolor truck bed coating. Truck bed coatings have maximum UV protection as they are assumed to be parked outdoors at all times. You could have it professionally sprayed with Line-X or Rhino, they will hold up very well.
Old Jan 9, 2021 | 07:51 PM
Hysteria's Avatar
Try 303 protectant to fight some of the sun damage. Parking it in the garage would probably be the best solution if you have room of course.
Old Jan 10, 2021 | 08:09 AM
The Deputy's Avatar
A loaf of bread has a better chance of outlasting a Land Rover...lol.
Just joking, couldn't resist.
Some sort of UV protector couldn't hurt, for sure. Plastic becomes brittle over time, causing failure.
Old Jan 10, 2021 | 10:29 AM
jacobmstein's Avatar
Ceramic coating or some sort of sealant would definitely protect it, however, I wouldn't worry about it. I got one out of a parts truck for $15 in perfect condition, I'd try looking in a Disco junkyard first. A guy I know that restores Discos says the new plastic ones don't fit as well as used ones.
Old Jan 11, 2021 | 09:38 AM
Tidder's Avatar
Thanks for the input everyone. I am going to get a UV protectant spray, like a top coat clear-coat spray. Due to the garage being full the disco will be parked out in the sun the majority of the rest of its life. Extinct, your truck bed coating idea is a very intriguing idea... I may try a couple of test pieces first and see how that turns out. Weather was bad this weekend so this will be a next weekend project.
Thanks again all!
Old Jan 11, 2021 | 09:44 AM
Best4x4's Avatar
Yep extreme heat makes the plastic brittle. I've never seen a D2 in TX without issues. The windshield cowl is mounted directly behind the engine bay and it gets heated from the engine, and the sun. It's honestly a no win situation. I've been curious about the fiberglass made unit I've seen off of Ebay.
Old Jan 11, 2021 | 06:02 PM
Extinct's Avatar
I bought one of the fiberglass cowls, fit nice. Does not have the factory vent grille for the cabin filter, you could obviously drill holes if you wanted. Strength, flexibility both better than an 18yo factory unit. Never handled a new OEM one so have no reference. Does not have the factory hooks.
Old Jan 11, 2021 | 07:14 PM
Tidder's Avatar
My understanding is the guy that made this in Malaysia, Rexypow(?), had passed away and one of his family members liquidated the stock. I haven't seen a fiberglass one for sale anywhere for a couple years now. Wish I would have pulled the trigger back then. Community lost a pretty special person doing some pretty top notch work.
There is another company now taking OEM parts and reenforcing them with fiberglass but I don't see any more aftermarket fiberglass parts anywhere.
AzjaST
Jan 13, 2024 06:36 AM
sayeedA
Feb 7, 2019 12:52 PM
huggi
Oct 5, 2016 12:53 PM
aguison
Nov 6, 2013 12:02 PM
krazzz
Oct 21, 2009 07:34 AM
