PS pump
Old Nov 14, 2024 | 10:36 AM
whowa004's Avatar
Default PS pump
Preferred PS pump these days? One I bought from rock auto lasted a few weeks until it got cold and screams like a banshee until warmed up but still has a stiffer feeling than the old leaking one I removed.
Old Nov 14, 2024 | 05:12 PM
Harvlr's Avatar
Look at the thread just below this one. I would recommend replacing the seal on your original pump.
Old Nov 14, 2024 | 06:45 PM
Best4x4's Avatar
So weird the D1 pumps from the same place as the Chinese D2 pumps = work fine vs D2 that quickly die, **** themselves immediately, or have the wrong sized mount for the pulley....
Old Nov 14, 2024 | 07:00 PM
Extinct's Avatar
D2 pump has a serious design flaw in the rear cover, gasket is too thin, too small a sealing land, and cover is too thing to allow significant tightening without cracking. Solution inbound but until then replace the gasket and tighten carefully.
Old Nov 17, 2024 | 09:12 PM
longtallsally's Avatar
Can you post the link? I didn’t see it and would like to know this one. My Alveston is a bit harder to turn and I’m thinking it’s the pump and was planning on replacing it as a means of seeing if I could make the steering easier. Thanks!
Old Nov 18, 2024 | 10:02 AM
whowa004's Avatar
https://landroverforums.com/forum/di...-angry-123959/
don't think it pertains to steering feel
Old Nov 18, 2024 | 10:11 AM
Feel isn’t the concern, it’s that it is harder to turn the wheel. My first D2 was really easy to turn the wheel, and my last 2 drivers have been more difficult. The Giverny is super easy (on the 30 seconds at a time is has run), so that leads me to believe something is up. I’ve not bled, but there is zero whine or noises and I’ve changed out fluid but not done a full flush. I just figured it was the pump being wonky? I’ll read that other thread and see what I come up with.
zuke
Nov 20, 2019 11:04 PM
Jared9220
Apr 28, 2014 10:57 PM
antichrist
Apr 26, 2011 02:00 PM
Testpilotb
Dec 14, 2009 11:16 AM
lipadj46
Dec 13, 2009 09:11 PM
