Pulling engine out
Old Mar 23, 2008 | 02:21 PM
kraelo's Avatar
Default Pulling engine out
I have everything ready to pull the motor out except un-mating it from transmission....
That cover facing forward bolted under the bell housing I need to take off to unbolt the flywheel from the torque converter ?
I have all the bell housing bolts off,
just curious if that is what I take off to get to the flywheel...
thanks guys
Old Mar 23, 2008 | 06:26 PM
socalrover84's Avatar
Default RE: Pulling engine out
thake the cover under the transmission bell housing with the three 8mm bolts on adn you'll see the teeth on flexplate. now remove the right hand side inspection cover on the oil pan its rubber and you should see the bolts the the torque convertor and flex plate just spin the transmission either by the teeth or by front crank pulley.
Old Mar 23, 2008 | 08:21 PM
kraelo's Avatar
cool, ty
Old Mar 23, 2008 | 10:33 PM
kraelo's Avatar
Since I have 2 motors, and both are out,should I rebuild the good one before I put it in ?
Rebuild the transmission while it's easy to get out ?
I'm gonna have the radiator cleaned and inspected ..
Accepting ALL Suggestions of things to do since im at this moment ....
Old Mar 24, 2008 | 05:06 AM
cplthomas's Avatar
I wouldnt rebuild the tranny unless something is wrong with it. Just because it has alot of miles doesnt mean it ready for a rebuild (unless there is something special about these tranny's that I dont know about).
Why would you rebuild a "good" motor?
Old Mar 24, 2008 | 05:18 PM
kraelo's Avatar
Cause it still has the steel head gaskets instead of the new composite ones...
After a fresh rebuild there's less of a chance of something failing, gasket, pump, things like that ...
A motor that has been considerably used and is at 90k miles isn't definately going to fail anytime soon, but it could ...
I'd rather do work while it's on a rotating engine stand compared to inside my engine compartment ...
Old Mar 25, 2008 | 08:58 AM
okdiscoguy's Avatar
There is room to do the head gaskets in the truck, but it wouldn't hurt to do them before you drop it in....especially with 90K.
Old Mar 25, 2008 | 01:12 PM
cplthomas's Avatar
ORIGINAL: kraelo
I realised as I was reading this that I didnt have enough info to answer your question properly, Sorry for that. I agree, there is nothing like doing work on a mill after its been installed and thinking "just why the heck didn't I do this while it was on the stand" I was thinking that when you said "good" you meant new.
Also, I now know that the head gaskets can be upgraded.
Old Mar 25, 2008 | 06:02 PM
kraelo's Avatar
How can I get the truck in neutral when it's in park ?
I connected the battery and tried to pull it out of park and didn't work...
Any other suggestions ?
Old Mar 25, 2008 | 07:24 PM
khuds308's Avatar
that one got me two. key has to be on.
