Put a new engine in. Oil light came on.
Old 12-20-2021, 09:52 PM
The Ocho's Avatar
THANK YOU EVERYONE!!!!
I bought an oil pressure sensor from harbor freight. Got it on there and at idle it’s 50 PSI.
OK so not the engine. Then I swapped out the sensor with a known good one from the old block.
No light and the thing works great now.
The following 5 users liked this post by The Ocho:
Brandon318 (01-01-2022), JohnZo (12-23-2021), sdtimb (12-25-2021), The Deputy (12-21-2021), whowa004 (12-21-2021)
Old 12-30-2021, 09:41 PM
nashvegas's Avatar
Received 1,156 Likes on 624 Posts
Great news but...
50 psi at idle? That's not right. Are you sure?
Old 12-30-2021, 11:07 PM
Received 1,148 Likes on 794 Posts
@Ocho that 50 psi right after start at idle or after getting to temp. If at startup that is good but you need the second number after you warm up. I get 50 at start 660 rpm and about 18-14 at 180F, running up to 2000 rpm gets me to the mid 40's
jetfixer
04-29-2019 07:38 PM
jacobthomas
01-07-2015 11:28 AM
bulldozer32
05-24-2010 10:30 AM
fx267
11-09-2008 01:55 PM
Quick Reply: Put a new engine in. Oil light came on.
