Puzzling
What would you do?
I have ultragauge.
Watching the temps....it starts going up, 210-220...I step on the gas and it drops to 194. While driving it seems to do fine, when your at a red light, it climbs.
I have already cleaned, flushed the radiator. No leaks.
Thermostat is about a year old, but is the normal stat not the 180°, I'm still running dexcool, and am thinking about changing it to green.
New reservoir bottle, new plastic coolant lines, new TBS heater.
I am going to check my electric fans, also the fan clutch and replace the cap for the reservoir bottle.
I have ultragauge.
With the truck off, if your key is in the on position and the a/c is on, you should hear your electric fan on. When you say step on the gas and the temp drops, is that in neutral at a light? If so, something is restricting the flow or the impeller is worn in the water pump?
Otherwise, definitely change from dexcool to the green and get an OEM Land Rover 180º t-stat.
I'd start with the fan clutch. Test it - should move with a bit of tension when cold, then be harder to move when hot. If it moves easily it's toast.
Although I would swap out the dexcool and lower thermo asap, I don't think it's your problem (yet).
If the fan clutch was bad enough to cause what he's describing, I don't think stepping on the gas would fix it. Thinking H2O pump as well, but either way, the Dexcool needs to be swapped out and a temp test done on the radiator. I've heard Buzz say it enough times that I can pretty much quote, measure top to bottom of radiator (get the car up to operating temp then turn off and measure). If there's a 10F difference, there's a clog and you'll need a new radiator since the plastic innards of these things can't usually be piped.
