Question on the 3 amigos?
You can also rent it for cheap.
My lights were on constantly because the shuttle valve switch had a bad solder joint in it.
I think the lights can be intermittant if there's a bad solder joint in the SVS circuit board.
Knowing what I know now, I'd pull the ABS unit, check the switch, check for a bad joint in the unit itself, perform the option b fix no matter what, put it back together and see if the amigos go out.
If the lights are still on, then I'd rent a abs amigo.
on
If your lights come on once in awhile, you have more of a soft fault, similiar to an engine code pending. If you catch it before the computer locks in a hard fault, lights always on, then you can save your self some grief. Have you inspected your brake pads, are they wearing out, how about your rotors, do your front wheels show a lot of brake dust or are your brakes squeaking? These are just a few things that will eventially trow a hard fault.
