Question on changing a coolant hose.
Old Feb 24, 2011 | 05:38 PM
Snafu / Disco Fries's Avatar
Default Question on changing a coolant hose.
I'm going to tackle changing the lower hose that goes from the thermostat to the engine (and a couple places). It is the one of the passenger side on the bottom (not the lower hose going to the radiator). Looking at the RAVE, and not sure it is answering my questions so figured I would throw it out to all of you:
1. How easy of a job is this, and is there anything big that needs to be moved to get at it?
2. How much coolant am I going to lose? The engine radiator and cooling system is new, so I don't need to do a flush but would like to change it out once this new hose is on so I know I have all of the same coolant brand/type in there.
Old Feb 24, 2011 | 05:39 PM
Here is the original picture I took of the spot. I'm pointing to the joint which is cracked. The big hose I'm pointing to connects to the thermostat just off camera to the right.
Old Feb 24, 2011 | 10:22 PM
willrok13's Avatar
(1) It is pretty easy to get to, you shouldn't have any problems.
(2) You are going to lose ALL of your coolant. If you are running DexCool, you want to refill with DexCool ONLY. If you want to change to green (or another type) coolant, you need to flush your system even though it is "fresh".
Old Feb 25, 2011 | 06:49 AM
unimoged's Avatar
Make sure you bleed the cooling system really well, otherwise it will overheat if air gets trapped in the external thermostat housing causing it to remain closed.
Old Feb 25, 2011 | 07:26 AM
So besides just taking that hose off, is there another preferred route to draining the system?
Old Feb 25, 2011 | 07:57 AM
Bundu's Avatar
Banned
That depends if you want to reuse the coolant or not. If you want to reuse the coolant then use a hand pump to drain the coolant tank first, then remove the top radiator hose and drain as much from the radiator and thermostat side as you can, then go to lower hoses until you reach the point where you want to work. There is no easy way to drain the coolant into a bucket, that would make life too simple.
If you do not want to reuse the coolant then pull the truck onto any surface that you do not care about and pop the bottom radiator hose off.
Old Feb 25, 2011 | 10:36 AM
Yep...sounds like another messy garage job! I'll get the drain pans ready!
Old Feb 25, 2011 | 10:38 AM
Bundu's Avatar
Banned
Do the hand pump method in the garage, any other way will flood your garage.
Old Feb 25, 2011 | 10:47 AM
I will drain what I could before I open the flood gates!
Old Feb 25, 2011 | 11:02 AM
Bundu's Avatar
Banned
The first time I did it I put a 5 gal bucket under and pulled the bottom radiator hose, coolant went everywhere except in the bucket lol
