Question regarding tranny fluid replacement
Old Dec 28, 2013 | 10:46 AM
redwhitekat's Avatar
Default Question regarding tranny fluid replacement
On my 2004 d2 I'm doing my tranny fluid replacement I began by removing my full plug first and about 2 litres came out of it is this Normal or was it overfilled ? I thought the fluid should be level with this plug
Old Dec 28, 2013 | 10:49 AM
jafir's Avatar
You fill the tranny when the engine is running and ATF is pumping through the tranny. Since the engine isn't running when you drain, it's higher than the fill level. So this is normal.
Old Dec 28, 2013 | 10:59 AM
Thanks so much just wanted to be 100 percent sure
Old Dec 28, 2013 | 12:28 PM
Externet's Avatar
Ouch !
So when Jiffy lube checked the level with engine off and only a few drops came out; means it is underfilled ?
Old Dec 28, 2013 | 01:06 PM
jeffh's Avatar
Originally Posted by Externet
Ouch !
YES. I would get that taken care of pronto. these trannies are built to take a lot of abuse but they need their fluid.
I would highly suggest not going to jiffy lube as they are really not versed in these trucks. especially with the tranny. for 30 bucks you can get the basin, the hand pump you need to take care of this on your own.
Old Dec 28, 2013 | 01:17 PM
No jiffy lube here I do all the maintenance my self and the truck has been runing well over the past 2 years
Trannys fluid replaced old fluid was still very clean I was surprised truck has 140000 km also put in the additive for trannys from lucas
Old Dec 28, 2013 | 01:40 PM
Externet's Avatar
Thanks Jeffh !
Am ordering immediately a Disco 1 Tube and dipstick; will adapt to my Disco 2 transmission and let know details of surgery. No more Jiffys, no more risks, no need for filling kits, just a funnel for peace of mind...
1998DiscoverySE
Jul 20, 2012 08:02 PM
03discoman
Dec 28, 2009 08:29 PM
smokey73
Oct 1, 2009 03:34 PM
LRScott
Mar 4, 2009 08:39 AM
jdelp
Jun 18, 2008 07:07 PM
