Questions about lifting and tires...
Old Apr 28, 2008 | 03:08 PM
andrew789's Avatar
4wd High
Default Questions about lifting and tires...
Alright I have a 99 Disco II. Currently I have 255/55 R18's on it. I want to put a 2.5" lift from toddcosuspensions.com on it to fit 33's. The thing is I also want to get rid of my 18's because to put 33's on 18's it would cost $1450 just for the tires (only 4). But I can get four 16" rims with 33's all for $1000.
I understand the bolt patter is 5x120mm, I was wondering if it would be possible to to use the 5x4.75 bolt pattern?
And finally; would I actually be able to use 33's with a 2.5" lift?
Old Apr 28, 2008 | 03:22 PM
NiteTrain's Avatar
Default RE: Questions about lifting and tires...
just a reminder...most 33's are not exactly 33"...some are larger and some are smaller. I believe goodyear MT's are smaller and I know interco tires (super swampers) are larger. They measure out to be 33.7".
Old Apr 28, 2008 | 03:42 PM
LRDISCO's Avatar
Im not sure if your going to be able to fit 33's with just 2.5" of lift. You will definately have to trim your front bumper so they wont rub, thats if they fit. I'd go with 31's or 32's.
Old Apr 28, 2008 | 04:10 PM
I have never heard of that lift.
Are you planning on the diffs, gears, axles and all the other stuff necessary to handle that size tire?
Old Apr 28, 2008 | 04:13 PM
andrew789's Avatar
4wd High
Negative I don't plan on changing anything at the moment. I just want to put the spacers in to fit bigger tires. Does anyone know what maximum tire size I could go up to with a 2.5" lift?
Old Apr 28, 2008 | 05:58 PM
So are you putting on spacers for the lift?
Old Apr 28, 2008 | 06:23 PM
andrew789's Avatar
4wd High
yes sir. i'm actually contemplating putting some 265/70 18's on there instead of changing the rims they come out to be a little less than 33 to be cheaper.
Old Apr 28, 2008 | 06:54 PM
If you put that set of spacers on top of your old warn out springs you will have the worst riding, top heavy Disco you could ever imagine.
Spacers can only be used along with H.D new coils and shocks.
Old Apr 28, 2008 | 08:55 PM
andrew789's Avatar
4wd High
www.toddcosuspensions.com and you can find the exact lift that i'm putting in. it's the 2.5" spacer lift...
Old Apr 28, 2008 | 08:57 PM
andrew789's Avatar
4wd High
i've ridden in a jeep that had a 3" spacer lift with 33's and the ride wasn't rough at all. why would this differ in a rover?
gunsanroses91
Nov 3, 2013 11:06 PM
photocrimes
Jan 3, 2012 12:33 AM
Spencerfitch
May 13, 2010 09:28 PM
manieldunk
May 2, 2009 10:07 AM
2001RR
May 17, 2006 08:40 AM
