quick question on ss brake lines install...
Old Aug 20, 2012 | 11:58 AM
bballjames's Avatar
Default quick question on ss brake lines install...
SS Brake Lines Install
In the sticky it says to use two new copper crush washers on for the inside and outside of each bolt. Anyone know the size of these? Just want to make sure I have everything I need before I start...
Old Aug 20, 2012 | 12:37 PM
jafir's Avatar
I bought the Goodridge lines from Roversnorth, and they came with washers.
Old Aug 20, 2012 | 12:39 PM
jafir's Avatar
Wow. I just noticed the price of the terrafirma lines at british pacific. They are only $72.50.
Land Rover parts, spares, Land Rover accessories - Search results for TF610L
Old Aug 20, 2012 | 12:54 PM
jafir's Avatar
The part number is 577475 or SYF100330, but I cannot seem to find the size listed anywhere.
Old Aug 20, 2012 | 12:59 PM
bballjames's Avatar
Thanks for the info. Wish I would've known about the british pacific a couple days ago... I bought mine from AB as they were on sale for $119... Hopefully they will come with the washers...
Old Aug 20, 2012 | 01:03 PM
jafir's Avatar
If not, just take the bolt out and take it to the parts store and match up a copper washer. Should be pretty cheap, I'd think.
Old Aug 20, 2012 | 01:42 PM
antichrist's Avatar
They appear to be 15mm OD x 11mm ID
Britcar (UK) Ltd > SYF100330 BRAKE HOSE COPPER WASHER RRC/DIS/NRR (G)
Old Aug 20, 2012 | 01:43 PM
FLDiscoII's Avatar
I just got my kit from AB a couple days ago. Came with all the washers you need. Definitely wish I had known about the TF lines.
Old Aug 20, 2012 | 04:23 PM
nychaze's Avatar
Made the same mistake...bought the lines from AB to find the TF lines 3 days later. DOH!
Old Aug 21, 2012 | 06:23 AM
coors's Avatar
X3 on the AB lines. Mine arrive todsy. Are TF lines extended for raise suspension?
