Quick Ujoint question
Old May 23, 2014 | 09:59 AM
Jared9220's Avatar
Default Quick Ujoint question
I'm leaving this forum and have deleted all my work in this thread.
Old May 23, 2014 | 10:49 AM
dusty1's Avatar
1. yes
2. dunno
3. hit the working cap with a few taps (mallet and something....i use a socket) should force free, the others
Old May 23, 2014 | 01:23 PM
ralphobell's Avatar
Try just replacing the zirc fitting first. They do get clogged and will not allow grease in. There is also a tool I think for cleaning them.
Old May 23, 2014 | 03:14 PM
WNYErikDiscoII's Avatar
Former Sponsor
I wouldn't replace it with a cheap aftermarket like that.
Id spend the extra $13 and go with something reputable for a part like this (Hardy Spicer)
Old May 23, 2014 | 05:10 PM
Motorhead1's Avatar
He was refering to beating on the u-joint/yoke some with a hammer to see if you could brake the dried up inerds of the u-joint free so grease would then flow..It's kind of an old last attempt to get grease inside a stuborn u-joint.
Old May 23, 2014 | 05:16 PM
dusty1's Avatar
yep. usually works and if not you're in the same uboat . like an impact greasing.
Old May 23, 2014 | 05:31 PM
OffroadFrance's Avatar
As an alternative, if the zerk is on the end cap take it out and then try probing by hand with different size twist drills to see which one fits into the UJ. Hold the drill with a T type tap wrench and gently screw it into the UJ withdrawing it regularly with the compressed dead grease. You might get lucky and the slug of solid grease gets removed and hey presto problem solved. Nothing to lose.
Résultats Google Recherche d'images correspondant à http://upload.wikimedia.org/wikipedia/commons/7/78/Tap_and_T-wrench.jpg
Old May 23, 2014 | 07:30 PM
Originally Posted by Jared9220
I beat the hell of the thing while trying to grease it and still the same results.
So back the original question. Is this Neapco 1-0005 a good replacement or is there another one that I should be considering?
I have seen the Neapco referenced in several rebuild threads and noticed that is made in the USA. If there is another (better) ujoint I am open to options.
I don't know about Neapco but these are reputedly the best UJ's https://www.google.fr/search?q=photo...m=122&ie=UTF-8
Old May 23, 2014 | 08:08 PM
Dane!'s Avatar
Just go to AutoZone and get the 13$ ujoint, if your in a hurry for your event. I haven't broken mine yet, I think I'd break something else before I broke the u joint.
My rear had the exact same problems your describing, I couldn't force any grease in there, and when I finally did clean the zerk, it only came out one seal. I replaced my old one for a VatoZone joint, and found that my old one had 3 cracked caps, which maybe was the reason why the grease only came out one seal, because there wasn't enough pressure to push it through? Dunno, but maybe you should check it out.
Old May 23, 2014 | 08:32 PM
Dane!'s Avatar
Its hard, 1310 series don't fit. They require a different flange iirc. Go with stock for now and then buy a rear HD shaft :P
