Quirky coilpack?
Old Oct 8, 2010 | 12:30 PM
jojoknox's Avatar
7th Gear
Default Quirky coilpack?
Forgive me please if this has been addressed elsewhere, but sometimes the obvious escapes me. Just swapped motor out of 01 DII with a 90k motor that passed compression test with flying colors. After chasing away a host of glitches, thanks to this forum, I am left with a lingering fault code p308. After reading numerous posts on the topic I was confident that magnecores would be my salvation. Not so! My question now is "can a coilpack fail on just one post?". Good compression, new plugs and wires, and no juice on jug #8 when online spark detector is connected. On a vehicle designed by compassionate beings, I would just swap coilpack and see what gives, but am quickly losing my appetite for working within the one inch playground the Rover engineers left us at the back of this motor. Any thoughts other than swapping coilpack?
Old Oct 21, 2010 | 12:40 PM
jojoknox's Avatar
7th Gear
Default Coil replaced
Cannot imagine that no one else has experienced this coil issue, but here is how it ended....as noted in initial post, no spark at plug and No light in online spark tester. However, I could get a light if tester was grounded directly, that is without plug in equation, which indicated a very weak spark. Went ahead and changed coilpack, and sure enough, #8 coil post was far weaker than the others. Problem solved.
Old Oct 21, 2010 | 02:01 PM
It is possible. Do you feel the miss, is it constant hot or cold, if so, I would do a compression test and get back to us with the numbers, you may have a valved burned or stuck from carbon.
roxburyrover
Jun 23, 2015 08:21 PM
cruzer555
Feb 28, 2015 01:22 AM
honda50r
Jun 30, 2011 11:38 PM
