Rad Leak stopper on rover?
Old May 23, 2011 | 11:30 PM
novavon's Avatar
Default Rad Leak stopper on rover?
Hey guys,
for the longest time i've had a tiny rad leak where i would fill up the coolant to the top every month (been doing this for 3-4 months now) and i just came across a flyer from my local Canadian tire that has a Motomaster Liquid Radiator Stop Leak on sale and was wondering if it would harm my vehicle in any way if i put some in?
Oh and the leak is very minimal, I've never seen a puddle anywhere but the coolant level keeps on dropping at a very slow rate.
Old May 24, 2011 | 12:23 AM
mwindth's Avatar
Originally Posted by novavon
Hey guys,
Yes, it will harm IMO...Have you pressure tested your radiator? Have you ever replaced your headgaskets?
New members must read! https://landroverforums.com/forum/di...st-read-26356/
Old May 24, 2011 | 05:07 AM
hilltoppersx's Avatar
agreed with above. don't use that crap, pressure test and find the leak and fix it proper.
Old May 24, 2011 | 07:41 AM
How many miles on your engine?
You will be a lot better off either having the radiator cleaned and replaired or replaced, don't gunk up your engine.
Old May 24, 2011 | 09:07 AM
DarylJ's Avatar
As others have said, stop leak isn't a good idea. Here's why:
In order to stop leaks, it has to coat the system with "stuff" that liquids won't pass through. Pretty obvious, right? The problem is that stuff also clogs thermostats (all of it says to remove the thermostat when you first put it in - which isn't possible without major bypass surgery on a DII), and coats the entire system with stuff that doesn't transfer heat as well as bare aluminum and/or copper, which reduces the efficiency of an already arguable undersized cooling system.
When you want to reverse this process, you may or may not be able to get all of the gunk out by flushing it (many times). Some people have had to replace heater cores because they haven't been able to get enough back out again.
Stop leak was fine for 1973 Pontiac Bonnevilles. Modern(ish) motors and cooling systems just don't take well to it.
Old May 26, 2011 | 12:30 AM
novavon's Avatar
Headgaskets have been replaced less than 15000km ago (9375 Miles)
I've been a member for a year now and I've read that. I'm more of a guy that loves rovers but have very little mechanical knowledge. I'll go to a specialist sometime this week (or next week and find out how much it'll cost to repair it)
It was just a thought, I know that over a long term, it probably won't be good for the vehicle anyways.
Just reached 140 000km (87500 miles)
Thanks for this explanation!
Old May 26, 2011 | 01:11 AM
mwindth's Avatar
Red face I was only trying to help you by getting background info on your rig.
Then why don't you at the very least, provide basic info on your Rover as politely requested in the https://landroverforums.com/forum/di...st-read-26356/ thread like everyone else here? I was only trying to help you by getting background info on your rig.
Old May 26, 2011 | 07:20 AM
vandev's Avatar
Default dont
dont do it..i have done in the past but is only a band aid.. a radiator on ebay is $200.00 new for aftermarket. A monkey can install the radiator....
NEW RADIATOR NATURAL LAND ROVER DISCOVERY CAR PART AUTO | eBay
XCELLER8
Jul 16, 2011 12:56 PM
mherson
Aug 24, 2009 10:03 PM
ajh
Jul 24, 2007 01:49 PM
Stashf
Jun 9, 2007 07:05 AM
Les
Jun 2, 2007 02:48 AM
